Guages not working?
Guages not working?
Postby z|gen » Sat Jul 10, 2010 4:35 pm
hey, just put new speakers into the corolla under the dash, but now none of the guages work and none of the dash lights come up - headlights, indicator lights still work fine, just no engine, oil or battery light?
anybody got any ideas?
thansk dave
AE91 SUPERCHARGED COROLLA
z|gen
Postby iOnic » Sat Jul 10, 2010 5:13 pm
Checked fuses?
Postby z|gen » Sat Jul 10, 2010 5:25 pm
under dash one seems sweet, are there any others hiding around the place? or linked off another fuse?
z|gen
Postby BZG Wagon » Sat Jul 10, 2010 6:26 pm
Check the fuses in the engine bay?
Have you accidentally unplugged anything? Checked cables coming from the cluster are all tight & secure?
BZG Wagon
Postby z|gen » Sat Jul 10, 2010 6:47 pm
yup, ALL the fuses i can see are fine.
didnt unplug anything near the cluster at all.. all work was done on the passenger side..
didnt go near the cluster
z|gen
Postby z|gen » Sat Jul 10, 2010 8:21 pm
have also now noticed that the heater and demister controls are not working either..
anybody got ideas on what i may have missed?
z|gen
Postby whynot » Sat Jul 10, 2010 8:58 pm
On an ae92 I am pretty sure the check engine,oil,batt lights and the gauges share only a common power supply. It really does sound like a blowen fuse or a broken wire. You might need to start testing and proving that the fuses and circuits are working.
whynot
Postby evil_si » Sat Jul 10, 2010 9:04 pm
dome fuse,
are the rear tail lights working?
evil_si
Postby z|gen » Sat Jul 10, 2010 9:11 pm
yup, all lights working normal as well.
charge light is back on now, still no other lights, guages or heater though.. :(
z|gen
Postby z|gen » Sat Jul 10, 2010 10:25 pm
anyone got any ideas on where i would find this fuse? google doesnt bring anything up about it.. just about the dome light which i assume is the interior light
z|gen
Postby loose_unit » Sat Jul 10, 2010 10:48 pm
Dome fuse is in the fuse box under the bonnet, causes all sorts of wierd things not to work.
91 GT Starlet 5efte
231kw atw @ 18 psi
12.13 @ 185kph
loose_unit
Postby z|gen » Sat Jul 10, 2010 11:01 pm
ahh k, narrows that part down then, il try swapping with my brothers car ones then and see what changes lol
thanks dude
z|gen
Postby z|gen » Sun Jul 11, 2010 11:44 am
havent had much luck, all i can see under there is relays?
anyone got a better idea before i call after hours sparky?
z|gen
Postby BZG Wagon » Sun Jul 11, 2010 1:51 pm
Are you actually checking the fuses with a multimeter? Have you tried exchanging a couple with the same value just to be sure?
If your fuses are sweet then the next thing will be finding a lose or broken connection somewhere.
BZG Wagon
Postby BZG Wagon » Sun Jul 11, 2010 1:54 pm
...and just to be sure to be sure: have you checked the 'dome' labled fuse under the bonnet?
BZG Wagon
Postby z|gen » Sun Jul 11, 2010 2:32 pm
all sorted now,
couldnt find the fuse labelled 'DOME', but decided to retrace all my wiring and replace every fuse and relay i could find, not sure what fixed it exactly, but its working again, so going to book into a sparky tmrw to get it checked and make sure there isnt a short somewhere iv missed.
thanks for your help guys :)
z|gen
