Question about mix/matching GT-FOUR parts
Postby angryface » Sat Jul 10, 2010 4:52 pm
Hey guys, I'm doing a GT4 conversion on my Mazdaspeed Familia GT-R, this has been done before. It's known that the ST205 is the strongest and most refined of the GT4 drivelines, so if I can use those parts I will. It's economical for me to purchase a ST205 rear end from Japland, but shipping costs equal that of the transmission, so I'd prefer to buy one locally. The ST205 Celicas weren't available in Canada, but the ST185s were, and I managed to find a couple of transmission locally.
The question: Can I use a ST185 front-end with a ST205 rear-end, using either a ST185 or ST205 propshaft? If not, what would be the issue preventing that? Gearing, length of propshaft, something else? Thanks
angryface
Postby ee904age » Sat Jul 10, 2010 5:48 pm
Im not sure about gearing, but I would guess the the shorter wheelbase of a Familia would require a custom driveshaft anyway. Why not just leave the stock GTR rear end in there??
90 SW20 Turbo - Project
90 SW20 N/A - Sold
ee904age
Postby strx7 » Sat Jul 10, 2010 7:15 pm
ee904age wrote:Im not sure about gearing, but I would guess the the shorter wheelbase of a Familia would require a custom driveshaft anyway. Why not just leave the stock GTR rear end in there??
because the rear diff and the transfer box need to be the same ratio
Postby angryface » Sun Jul 11, 2010 2:03 pm
So I guess that means... no, drats.
Actually, the driveshafts fit perfectly. Well, we use spacers for the rears to push it out about an inch, but they even fit in our hubs perfectly.
angryface
Postby iOnic » Sun Jul 11, 2010 2:32 pm
He meant the prop-shaft from the gearbox to the rear diff
Postby Malcolm » Sun Jul 11, 2010 3:06 pm
all GT-Four rear diffs have the same ratio, mixing a matching ST185 and ST205 boxes and diffs will be fine. They might even be the same part anyway
Postby angryface » Sun Jul 11, 2010 5:34 pm
Good info you guys, thanks.
For axles, ST185 and ST205, I heard that they're interchangeable in a ST185 gearbox. I haven't found anything about the hubs, do the hubs from both generations accept the same diameter + spline count axle?
angryface
Postby strx7 » Sun Jul 11, 2010 8:09 pm
in the front i know they interchange, cant see why the backs wouldn't
i'm 99.9% sure the outers are all interchangeable. 4wd corolla and gt4 all have same splines
Postby DeeCee » Sun Jul 11, 2010 10:02 pm
there are some differences in width and control arm locations between st185 and st205. But that is a moot point since I imagine that you'd be making up new mounting points for the control arms to attach to.
GT Four Adovansu
DeeCee
Postby Scottie » Sun Jul 11, 2010 10:29 pm
angryface wrote:Good info you guys, thanks.
ST205 front axles are longer than ST185/165 items. Splines are the same.
Rears I am unsure about. Can check tomorrow.
Scottie
Postby Anth_555 » Sun Jul 11, 2010 10:36 pm
from what i been told the st205 run a wider wheelbase then st185 , with longer drive shafts are you using celica hubs or mazda hubs?
-1994 GT4 Celica ST205 project
-1984 Trueno AE85
-1993 Surf LN130
Anth_555
Postby Malcolm » Sun Jul 11, 2010 11:04 pm
Anth_555 wrote:from what i been told the st205 run a wider wheelbase then st185 , with longer drive shafts are you using celica hubs or mazda hubs?
wheelbase = length, track = width :)
just fyi...
Postby Anth_555 » Sun Jul 11, 2010 11:11 pm
correction track is wider
-1984 Trueno AE85
-1993 Surf LN130
Anth_555
Postby sergei » Mon Jul 12, 2010 9:00 am
I have both ST165 and ST205, and ST165 has way fatter front axles (roughly by 30%).
Also You cannot use ST205 axles in ST165 due to wider track.
The gearboxes and diffs are interchangeable. Make sure you get LSD diff (preface lift ST165 and some export ST185 didn't come with LSD).
Postby angryface » Mon Jul 12, 2010 7:08 pm
This is what we do to swap the GT4 driveline into the 4WD Familias/323s
    Celica 4WD (st165/st185/st205) transmission
    Order/fab Mazda engine/Toyota transmission adapter plate
    Slightly modify the transmission housing to accept the Mazda starter
    Toyota gear shifting assembly
    Fab new transmission mounts
    Use the Mazda flywheel
    Mazda clutch modified to fit the Toyota spline
    Toyota clutch master/slave
    Mazda hubs all around (Toyota outer splines fit like a glove)
    Toyota front axles, unmodified
    Toyota rear axles, 1" spacer between rear LSD & axles
    Toyota propshaft
    Toyota rear differential
    Modified Mazda rear differential brackets, or modified Toyota differential bracks (less popular)
    Notched oil pan to clear the center differential
To my knowledge, nobody has tried to swap st205 bits into the GT-R. I'm researching track widths to see how big of a difference it is, don't want to deal with binding cv joints and custom axles if I don't have to.
I have a hunch that st205 axles in the front would cause a problem, not sure about the rears, might not need to use the spacers with st205s in the rear... I'll try to get some dimensions... anyways, I ended up finding a complete driveline + shifters + clutch master for $200... talk about a real steal!
angryface
Postby angryface » Tue Jul 13, 2010 3:16 pm
Just so you guys get an idea of why we do this... here's a comparison pic of the two gearboxes...
angryface
Postby fangsport » Tue Jul 13, 2010 4:24 pm
is this road or rally use??
this is quite a common alternative to using the $pendy X-trac unit in Europe .
unsure how many dead GTX/GT-R boxes i have seen due to there weak casings causing the gears to climb out of mesh.
fangsport
Postby angryface » Thu Jul 15, 2010 1:58 pm
fangsport wrote:is this road or rally use??
It'll be for rally use, but it also needs to remain street legal as some portions are on public roads and rally here is still a minor sport with little governmental support. I also needs to multipurpose as a street car for a few days at a time, when I'm working in the hills. The engine will be powered by a GT28 and a GT35/40 in a compound setup, so there will hardly be any lag and I will be in boost at the 2k RPM mark and up ^.^
angryface
Postby frost » Fri Jul 16, 2010 1:13 am
[quote]GT28 and a GT35/40 in a compound setup[quote]
holy crap that is madness,
so the gt35 blows through the gt28 and then feeds the engine correct?
are you going to intercool the charge between the turbos or after the two turbos? or both,
i would love to see some pictures when you finish this set up,
Postby angryface » Fri Jul 16, 2010 1:38 pm
Correct, the outlet of the GT35/40 feeds into the inlet of the GT28r, which multiplies the incoming pressurized air. I plan to run a single intercooler between the GT28r and the engine.
angryface
