BZR4AGE wrote:
and I am using Link ecu now, so knock and oxy sensor are not used, so those are out of the questions.
So you are using a LINK ECU as a stand alone ECU not a piggy back
and it still does it?
I presume this is the stutter/hesistation that they have especially when cold?
I always assumed it was an ECU related problem, and never bothered to try to fix our one, but if not I may have a go at it.
Matt
BZR4AGE wrote:The funny thing is, when we went around puke on a test day with a wide band...the A/F was perfect even when jerking....
Thats why is a BIG MYSTERY!!!! if it was definately the fuel pump at fault, I would expect the engine to lean out. But then, there is nothing else I can think off that Link controls that standard ECU also controls. (I make this comparision because my sluttering happen even when I had stock cams and stock ECU).
cat007 wrote:Please stop saying sluttering. It's causing me to nurse a semi
neo wrote:subscribing to the thread
My silvertop daily has always done this, especially when the air temp is cold [winter], and low revs, low - moderate load.
Anyone swapped out the coil + ignitor?
BZR4AGE wrote:neo wrote:subscribing to the thread
I did, didn't help. But the ignitor was a second hand one...but what are the chances of both my old one and this one being faulty???
91 ZERO wrote:Have purchased an AE82, with a 4AGE 20v blacktop. Runs a factory 4AGE 20v computer. Engine wise, it is relatively standard (no air filter set up which I am about to change though). Previous owner last raced it many months ago and has been sitting idle since. He hasn't changed anything since then either.
It starts fine and idles sweet (maybe a little high at around 1300rom when cold). However under load - driving up a steep drive/moderate or heavy load it misses/hesitates like nothing on earth. It feels like it wants to go, but jerks heavily.
I initially thought ignition, so I have replaced:
Plugs
Leads
Dizzy cap
Rotor
oh - and a new fuel filter as last one was clogged.
After all that, it still does misses like crazy. I am now thinking possibly the coil pack, or possibly the fact that the fuel in the tank is totally sh!t house. Anything else I should look at? Is a diagnostic worth a shot to try pick up an error code?
