CV removal
CV removal
Postby pc » Mon Jul 12, 2010 11:41 pm
I've got another stubborn CV and I'm wondering what real mechanics do after the "smash at it with a big hammer until you run out of breath and all the stuff on the bench has fallen onto the floor" stage?
I'm thinking of cutting the cage with the angle grinder till the cup comes off and then carefully grinding a groove into the bit left on the axle and splitting it the rest of the way with a cold chisel.
Any better ideas?
red car
1/4 mile - 14.683s @ 91.83mph
Manfield - 1:24s
pc
Postby thegreatestben » Mon Jul 12, 2010 11:54 pm
Stick it in a big press. Bigger hammer. Soak with something like wurth Rostoff
thegreatestben
Postby Lloyd » Tue Jul 13, 2010 2:51 am
Hit it harder. If the outside comes to bits (thus showing you're hitting it hard enough) then cut the centre off. Someone of them just don't move and you have to cut them
Be happy its not a Subaru
Postby Dell'Orto » Tue Jul 13, 2010 6:41 pm
Mechanics generally go to a gas axe if hammers dont work ;)
Postby ee904age » Tue Jul 13, 2010 6:49 pm
Dell'Orto wrote:Mechanics generally go to a gas axe if hammers dont work ;)
Just beware of super hot grease :!:
90 SW20 Turbo - Project
90 SW20 N/A - Sold
ee904age
Postby rollaholic » Tue Jul 13, 2010 7:23 pm
its a toyota huh! are you replacing the CV, or the boot?
if its the boot, you can remove the inner CV and slide the boot down over the outer. if its the CV... as above. or pay someone
if you are pro with a gas axe you can cut the centre off without damaging the shaft
Postby CAMB01 » Tue Jul 13, 2010 9:01 pm
Have removed stubborn CV's by angle grinding the hell out of it.
1993 Mitsubishi EVO 1 Racecar
1989 AE91 FX-ZS (Previous)
Custom Works Automotive
http://www.HCCC.org.nz
CAMB01
Postby pc » Wed Jul 14, 2010 12:34 am
done. big cutting disk for the cup & cage, dremel with small thin cutting disk for the rest.
slow and painful :x
red car
Manfield - 1:24s
pc
Postby tsoob » Wed Jul 14, 2010 10:10 am
yeah press is the way foward if your hammer is tooo weak :wink:
sounds like its pretty much welded its self to the hub
Platinum Wheels
15 Parkway Drive
Mairangi Bay
09 486 5317
WHEELS, TYRES & SUSPENSION!
www.platinumwheels.co.nz
tsoob
