strx7 wrote:knowing toyota engines, you'll probably need to use the rocker cover and gasket from the dizzy engine and the inlet cam from it too. the rest of it should be all the same
sergei wrote:strx7 wrote:knowing toyota engines, you'll probably need to use the rocker cover and gasket from the dizzy engine and the inlet cam from it too. the rest of it should be all the same
Inlet cam might even have right cut out....
Infinite wrote:na runs crank sensor
