1hdt torque specs
1hdt torque specs
Postby evil_si » Fri Jul 16, 2010 8:13 am
any one able to help me out with engine bolt torque specs for a 1hd-t
evil_si
Postby rollaholic » Fri Jul 16, 2010 1:32 pm
what are you looking for specifically? i've got an old diesel manual here that covers 1HDT in a HDJ80 cruiser.
Postby rollaholic » Fri Jul 16, 2010 1:43 pm
heres what its got
head bolts - 69nm, 90 deg, 90 deg
main bearings - 103nm, 90 deg
big end bearings - 37nm, 90 deg
flywheel - 127nm
clutch plate - 39nm
crankshaft pulley / damper 490nm ( O.o )
cam sprocket - 98nm
camshaft carrier / cap - the front one is 25nm, the rest are 18
it also has specs for 1HDFT in same chassis, and more numbers for injector pump bits n bobs, brakes etc if you need.
Postby sergei » Fri Jul 16, 2010 1:45 pm
490Nm???? jesus christ
Postby FANGIN » Fri Jul 16, 2010 3:05 pm
It is a diesel remember
1998 AE111 Carib - For Sale!
1999 JZS161 GS300 - Tow Wagon
1986 FC3S - 410wkw Drag / Track Toy
FANGIN
Postby evil_si » Fri Jul 16, 2010 7:28 pm
sweet cheers rollaholic,
ive got an engine to assemble, but that should be enough for now, will be in touch if i need any other info
evil_si
