Thinking of swapping gearbox
Postby siren676 » Fri Jul 16, 2010 2:02 pm
I have a 1998 toyota starlet n/a and its got a c140 gearbox (4 speed).
It is really useless at motorway speeds with engine doing 3100rpm @ 100kph which seems really uneconomical.
Can anyone recommend what gearbox i should be looking at swapping into it?
Also should i be looking at putting a new clutch in now or when i eventually put in a 5e engine?
siren676
Postby sergei » Fri Jul 16, 2010 2:38 pm
Anything with 5 speed that fits, say cynos/starlet gearbox (not diesel ones, those have horrible gear ratios).
Postby siren676 » Fri Jul 16, 2010 2:55 pm
Which is better c56 or c52?
siren676
Postby sik_gt_starly » Fri Jul 16, 2010 3:17 pm
3100rpm is about right for a smaller engined car at 100km/h, my 4age trueno does about that, my 5efte starlet revs a tad lower
sik_gt_starly
Postby siren676 » Fri Jul 16, 2010 3:30 pm
Yeah but i would prefer it to be a bit lower. the motor sounds like it wants to explode
siren676
Postby Boosted_162 » Fri Jul 16, 2010 3:48 pm
My swift does even worse than that. 100k in 5th is about 3300-3400 :(, altho in a lightweight car with small motor, the close ratios do make it more fun :D
Re: Thinking of swapping gearbox
Postby BZG Wagon » Fri Jul 16, 2010 3:53 pm
siren676 wrote:I have a 1998 toyota starlet n/a and its got a c140 gearbox (4 speed).
My BZ Rolla sat roughtly there in fifth. From memory so did the 6-speeds.
Wouldn't be surprised if you found a 5 speed has the same final rato, just more gears in between.
BZG Wagon
Postby B_giB » Fri Jul 16, 2010 3:54 pm
My old AE86 was at 4000 rpm in 5th at 100 lol
Current: SXE10 Altezza
Previous:AE86 Trueno Notch Back: Gone but not forgotten :cry: :(
AE101 Levin 20V super strut
1994 Mercedes Benz C280 Sport
B_giB
Postby Quint » Fri Jul 16, 2010 4:23 pm
My hilux does about 3,000 rpm at 100... if the straights long enough.
Quint
Postby .:O4AGTZ:. » Fri Jul 16, 2010 4:40 pm
my old ae82 FXGT was something like 3200 at 100. ae101 GTZ was about 2800ish maybe?
.:O4AGTZ:.
Postby Malcolm » Fri Jul 16, 2010 5:07 pm
well my zxr does about 9,000rpm in 6th at 100km/h
Postby ee904age » Fri Jul 16, 2010 6:30 pm
I think this will most likely be the case.
90 SW20 Turbo - Project
90 SW20 N/A - Sold
ee904age
Postby Dell'Orto » Fri Jul 16, 2010 7:09 pm
I wouldnt think so, most 4th gear ratios are 1:1, with an over driven 5th. Or it would at the very least have a different final drive ratio
Postby matt dunn » Fri Jul 16, 2010 8:27 pm
Dell'Orto wrote:I wouldnt think so, most 4th gear ratios are 1:1, with an over driven 5th. Or it would at the very least have a different final drive ratio
Only in a RWD box,
Most FWDS are not 1:1 4th.
Postby DexGT » Fri Jul 16, 2010 8:47 pm
A C52 from a starlet will be doing 2700 rpm at 100km/hr due to the 3.7 diff. If you get one from a corolla (which wont fit your motor) it will have a 4.3 diff and be doing 3300 ish at 100km/hr. You could also look at the 5 speed off any non turbo starlet C150 I think , which should also be better than what you have .
DexGT
Postby ee904age » Fri Jul 16, 2010 9:02 pm
Or "chuck some 20's on it bro"
90 SW20 N/A - Sold
ee904age
Postby siren676 » Fri Jul 16, 2010 9:25 pm
ee904age wrote:Or "chuck some 20's on it bro"
I dont think 72hp will even spin 20's. Anyway im getting some SSA Rush mags soon (15's).
Ill start looking for a c52 from a starlet. Anyone know how much they are or where ill get one from?
siren676
Postby QikStarlie » Fri Jul 16, 2010 9:36 pm
just grab a box out of a cynos, (pick a part after some one takes the engine, easy) as someone else said. for what you want, starlet c52's are overpriced, syncros are usually stuffed and it'l probably make your car slower if anything.
reving much lower at 100k, you'l probably find you will use more gas. as you'l be further down the pedal to keep the same speed
QikStarlie
Postby siren676 » Fri Jul 16, 2010 9:58 pm
i actually want a 1.5l out of a cynos so might have to get both when i have the cash
siren676
Postby QikStarlie » Fri Jul 16, 2010 11:22 pm
yeh i know, its kpr from starletcentral. get back over there ! :D
QikStarlie
