Creaking in AE101 Fuel Tank?
Postby waywrd » Fri Jul 16, 2010 4:16 pm
Good afternoon all,
I had a problem with a crack in my original fuel tank so I bought one from a member and once I put it in and filled it up, I have noticed that it creaks all the time when slowing down and parking. Anyone else have this issue and is there any remedy for this?
Also happened on my old FX-GT AE101.
Cheers all
J
waywrd
Re: Creaking in AE101 Fuel Tank?
Postby salival » Fri Jul 16, 2010 9:49 pm
waywrd wrote:Good afternoon all,
Cheers all
J
Hiya,
The internal baffles could be loose or becoming loose.. Not an easy fix without removing the tank..
salival
Postby lowglrolla » Mon Jul 19, 2010 11:16 pm
its not the rear sway bar bushes is it ? i used to have a funny squeek for ages until i replaced them
92 gtz trueno
89 gtz levin
lowglrolla
Postby neo » Tue Jul 20, 2010 10:47 am
its the internal baffles.. They always come loose in the fxgt's for some reason..
cant be fixed, gotta be replaced. On the upside, a fuel tank from any ae10x will work (sedan, hatch, levin, fx etc)
Photo of the inside of one of my old tanks, you can just see a line on the bottom where the baffle is scraping along the bottom of the tank
neo
