ST205 RF axle
ST205 RF axle
Postby strx7 » Sun Jul 18, 2010 10:51 pm
Has anyone got an st205 rf axle out that they could get some measurements off for me? and possibly a pic?
basically need to know the depth the inner cv goes into the transfer box from the seal surface to the end of the spline.
Postby Scottie » Sun Jul 18, 2010 11:50 pm
I think right side is the one on the right.
32mm spline length
Scottie
Postby strx7 » Mon Jul 19, 2010 8:14 am
yip RH has the O-ring on it. and they are definitly ST205?
Postby Scottie » Mon Jul 19, 2010 8:53 pm
Yes. def 205 ones
Scottie
Postby strx7 » Mon Jul 19, 2010 11:08 pm
hmm I think i've worked out the issue. can anyone post a pic of the transfer box internals from the epc from an st205? toy-diy doesn't seem to work for the st205 frame number
Postby Scottie » Mon Jul 19, 2010 11:23 pm
http://www.toyodiy.com/parts/p_J_199411 ... _3610.html
Look at me, being all helpful and stuff :o
Scottie
Postby strx7 » Mon Jul 19, 2010 11:42 pm
when i put 205-blmvz into toyo diy it doesn't work and says "no record found"
Does anyone have a "41337" they'd like to part with?
Postby Scottie » Mon Jul 19, 2010 11:47 pm
I tried ST205-randomnumbers and I couldn't get it to work so used the chassis number off an actual car.
ST205-0006832
Scottie
Postby sergei » Tue Jul 20, 2010 12:43 am
strx7 wrote:hmm I think i've worked out the issue. can anyone post a pic of the transfer box internals from the epc from an st205? toy-diy doesn't seem to work for the st205 frame number
Just out of curiosity what are you trying to achieve? I have some knowledge related to right hand CV that I had to adapt to fit in ST205 box - is this where you are heading?
Postby strx7 » Tue Jul 20, 2010 8:12 am
I'm trying to make my car go......
I am missing that thru axle shaft which gives drive from the side gear of the front diff to the RF axle.
Postby sergei » Tue Jul 20, 2010 9:06 am
http://www.toyodiy.com/parts/p_J_1991_T ... l?hl=41337
It looks like exactly same part is found on ST185 celica, and ST165 with viscous center (no diff lock, face lift model):
http://www.toyodiy.com/parts/p_J_1989_T ... l?hl=41337
Postby strx7 » Tue Jul 20, 2010 11:18 am
yes, has to come out of a wide cog gearbox mated to a viscous transfer box
