Simple Q: ECU
Simple Q: ECU
Postby TazzieDevil » Sun Jul 18, 2010 10:59 pm
I have a manual 89 Celica that may have a dud ECU, need a new one as everything else has been checked out as fine. However, most of the Pick a part Celica's and those on Tard ME are auto. Will an Auto ECU be the same as a manual? or not?
Get In, Sit Down, Shut Up & Hold On
TS Profile
It wasn't Me, it was the one armed Man!
TazzieDevil
Postby frost » Mon Jul 19, 2010 12:15 am
no
Postby blindnz » Mon Jul 19, 2010 2:13 pm
The question maybe better. Could you run the Auto ECU and short some pins etc... on the ecu to tell it is netural?
blindnz
Postby Quint » Mon Jul 19, 2010 4:51 pm
If the auto ecu has an inbuilt ect you'll have to trick it into thinking it's in neutral so it can start, shouldn't be an issue. You'd have to check whether the auto ecu would survive without an input from the box, some ecus will run in limp mode or wont start. Others are happy to just have the auto inhibitor shorted.
Quint
Postby matt dunn » Mon Jul 19, 2010 7:33 pm
Quint wrote:If the auto ecu has an inbuilt ect you'll have to trick it into thinking it's in neutral so it can start, shouldn't be an issue. You'd have to check whether the auto ecu would survive without an input from the box, some ecus will run in limp mode or wont start. Others are happy to just have the auto inhibitor shorted.
Neutral start is not donr through the ecu so will have no effect.
Chances are if it physically plugs in it will work,
But I would bet that it probably wont even plug in as the connectors will be different.
Re: Simple Q: ECU
Postby neo » Tue Jul 20, 2010 10:52 am
TazzieDevil wrote:I have the worlds most plagued with issues 89 Celica
ahmen
neo
