Malcolm wrote:I didn't know they had maths on waiheke
h8wrxs wrote:dont need spring compressor with lowering springs, just need a mate to put weight on the spring when your undoing/doing the top nut up
Mr Revhead wrote:h8wrxs wrote:dont need spring compressor with lowering springs, just need a mate to put weight on the spring when your undoing/doing the top nut up
Not true for all applications. DO NOT ATTEMPT
h8wrxs wrote:Mr Revhead wrote:h8wrxs wrote:dont need spring compressor with lowering springs, just need a mate to put weight on the spring when your undoing/doing the top nut up
mmm fair call i have seen it done wrong, springs do come out of the strut REALLY fast if youre not careful lol
Alex B wrote:To be fair you're never going to fit into OS unless you hate on TS.
tsoob wrote:its pretty straight foward,
you will need a decent socket set, spring compressors, jack etc.
Remove the wheels, take the brake lines off the strut, remove the sway bar (do both sides so you dont fight the sway bar)
Remove the 2 big bolts to remove the strut from the hub.
Take the 3 bolts off the top, and remove your shock.
Compress the spring, and remove the top nut. change the pring over and do the reverse to put it back together.
Failing that bring the car to my workshop.. best record for this job with 2 of us doing it is a little over 40 mins
