Any ideas what could be the issue? Ill provide more info if needed, just not sure what else to note
Vertigo wrote: developed a significant whine in first gear, somewhat also in second, but fine in the rest.
MAGN1T wrote:Some gearboxes use tapered bearings which need to be shimmed correctly, When they get worn the gears don't mesh properly so whine and get worse and worse.When you pull them to bits you'll see the gears with uneven wear.
Sometimes the noise just comes from a worn out input bearing.
Steve
allencr wrote:Vertigo wrote: developed a significant whine in first gear, somewhat also in second, but fine in the rest.
Bearing & gear noise from wear builds gradually, it takes years for it to be called 'significant', so is this a sudden new noise or one that has been slowly increasing?
How is it when sitting still in neutral pedal up, then in 1st with the pedal down?
Any noise or hum disappear when the pedal is depressed, that's from worn bearings? Gears that are OK can make noise when the bearings are worn, cause the gears will be a bit out of alignment.
