Correct Spark Plug Gap - BKR6E??
Postby l1ttle_d3vil » Sat Jul 31, 2010 2:44 pm
What is the correct gap for BKR6E spark plugs? Running on a 4age turbo.
Tried googling but can't get a proper answer...
Postby Dell'Orto » Sat Jul 31, 2010 5:10 pm
They'll be pregapped at 0.8mm...maybe close them up a bit if you're running high boost
Postby MR2BOY23 » Sat Jul 31, 2010 5:24 pm
If NGK plugs are set at anything other than 0.8mm, it will say in the part number e.g bkr6e-11
MR2BOY23
Postby l1ttle_d3vil » Sat Jul 31, 2010 5:38 pm
Dell'Orto wrote:They'll be pregapped at 0.8mm...maybe close them up a bit if you're running high boost
12 - 14psi is about the highest boost I would be running. Figured they would probably be fine as they are but thought I'd check.
Postby MAGN1T » Sat Jul 31, 2010 7:33 pm
The correct gap depends on how much boost you're running.
They're normally pregapped at 1.1mm , that's the ones with 11 at the end.
.8mm works better but .65 works better still with no misfire at high boost levels, at least in a Mitsi with stock ignition.
If the gap is too big , it'll misfire when the boost rises. 1.1mm is OK for a stock turbo car.
Steve
Computers make you go mad.
MAGN1T
!USER HAS BEEN BANNED!
Postby matt dunn » Sun Aug 01, 2010 9:37 pm
MAGN1T wrote:They're normally pregapped at 1.1mm , that's the ones with 11 at the end.
Actually normal is 0.8mm.
Anything that is not at 0.8mm will have a gap prefix on the end,
which is why 99% of the 0.8mm plugs have no gap prefix.
Postby Heylin » Mon Aug 02, 2010 1:56 pm
Ive run both BKR6E and BKR7E in the MR2 at 16-18PSI. Never ever gapped them in over 100,000 kms of driving, just used them out of the box.
Heylin
Postby tsoob » Tue Aug 03, 2010 11:05 am
i have mine closed down to .6, but im running 20 psi.
Platinum Wheels
15 Parkway Drive
Mairangi Bay
09 486 5317
WHEELS, TYRES & SUSPENSION!
www.platinumwheels.co.nz
tsoob
Postby thegreatestben » Tue Aug 03, 2010 11:07 am
Mine are at .4 and they're choice.
I use R5671a-8 NGK's. They replaced BCR8E
thegreatestben
