3S-GTE into L200
3S-GTE into L200
Postby ee904age » Sat Jul 31, 2010 10:20 pm
Since I have a De-Reg SW20 which I CBF finishing and an L200 Diesel ute which is damn handy to have but rediculously expensive to register, I put 2 and 2 together and had a crazy thought. Why not put the 3S into the ute.
I have a mig, grinders, engine crane, access to a decent size garage and most of the knowledge to go with, but is there anything particularly hard about this?
I have read that all Toyota diesels use the 3S bellhousing, is this true? If so, what would be the best gearbox to handle the power of a stock 3SGTE yet still have useable ratios?
Other than the obvious distributor location, what else is involved in converting the 3S to RWD? Also, any hints on overcoming the dizzy problem much appreciated.
I have another car which I can use as a daily driver so this being a long term project is no biggie. I figure selling the 4D56 and associated bits would probably cover approx half the cost of the conversion, so would this be a reasonably wallet friendly conversion considering I already have the ute and the donor car?
OR, should I put this in the too hard basket and forget the idea all together?
Cheers,
Shay.
90 SW20 Turbo - Project
90 SW20 N/A - Sold
ee904age
Postby Dell'Orto » Sat Jul 31, 2010 10:49 pm
C series diesels do I think, and they bolt to W boxes, so you could get a W58 and mash the bellhousing on it. Mounting it slanted would be the least issue I would imagine, straightening them up requires a bit of mix and matching of parts
Postby gasman » Sat Jul 31, 2010 10:52 pm
do it. if the can do 4g63 l300 then a 3s cant be too far off
"What can possibly go wrong?"
gasman
Postby 3T-Rona » Sun Aug 01, 2010 12:30 am
hmm seems like a bit of a miss matched cross bred mongrel, could part out the sw20 and buy a 4g63b and the associated bits to bolt it in......
keeps it in the same family, just my 2c, not one for cross breading.....
PM me for anything autoelectrical, Info or jobs etc....
3T-Rona
Postby rollaholic » Mon Aug 02, 2010 8:35 am
re-reg the SW20, much cheaper! and more fun to drive.
unless all you care about is skids :D
unless you know of some reason why it would fail miserably, like rust or accident damage
