how long are ae86 axles?
Postby ke25sr » Tue Aug 03, 2010 9:45 pm
suprised not to find this on net?
i need to know the axle length on a stock axle,
ke25sr
Postby Simon86 » Wed Aug 04, 2010 1:42 pm
Presumably from the splined end, to where?
I have some out so can measure for you tonight.
Simon86
Postby ke25sr » Wed Aug 04, 2010 1:43 pm
Simon86 wrote:Presumably from the splined end, to where?
say from splined area to the hub face, or whatever you can do,
ke25sr
Postby rollaholic » Wed Aug 04, 2010 3:26 pm
LSD and non LSD are different length
about 5mm from memory (with no LSD being longer)
you cant use non LSD axles in standard LSD heads without bad results (found this out the hard way) though apparently some aftermarket centres accept either type
Postby ke25sr » Wed Aug 04, 2010 4:04 pm
rollaholic wrote:LSD and non LSD are different length
great, knew that allready, i just machine the end off. But what i need is total lengths
ke25sr
Postby rollaholic » Wed Aug 04, 2010 5:15 pm
yep i realise what you are after
i was just trying to be helpful / save potential problems :)
Postby ke25sr » Wed Aug 04, 2010 5:21 pm
rollaholic wrote:yep i realise what you are after
Thanks
ke25sr
Postby Simon86 » Wed Aug 04, 2010 9:33 pm
From hub face to end of spline 684mm +/- 1mm
They are facelift if it makes a difference...
Simon86
Postby ke25sr » Thu Aug 05, 2010 9:09 am
Simon86 wrote:From hub face to end of spline 684mm +/- 1mm
thats fantastick, exactly what i needed, awesome thanks, The coupe will be back on road real soon now
ke25sr
