ae101 fxgt boot leak??
Postby grant76 » Wed Aug 04, 2010 3:25 pm
Just wondering if this is a common problem with the ae101's, i had an ae92 fxgt that leaked a little in hard rain in the wheel well but was wondering if it was the same in the newer models?? Hopefully as simple as a slightly stuffed boot rubber?? or is this not usually seen in these??
grant76
Postby metal_sean_head » Wed Aug 04, 2010 4:17 pm
Could be leaking through the lights?
VTEC: All of the lag and none of the boost.
89 AE92 FXGT
Big Port Redtop
TVIS!
19.8@32kph
metal_sean_head
Postby grant76 » Wed Aug 04, 2010 4:21 pm
i dont think so, the middle channel of the boot seal was full with water, but i'll have a closer look at the lights as well
grant76
