http://www.trademe.co.nz/Trade-Me-Motor ... 993341.htm
copy from auction=
Toyota GT4 MR2 Caldina 3SGTE Chromoly Flywheel
New Zealand Automotive Distributors Ltd
We are distributors of replacement and performance automotive parts.We cover most makes and models please ask!!
D1Racing,SECO,Exedy,ACT, Sachs ,LUK, Brembo,Zimmerman,ASIN,NUK,GMB,Airtex,Gates
Brand new Chromoly lightweight flywheel to suit 3SGTE 2.0 turbo in
Celica GT4 ST185 ST205
MR2 SW20
Caldina ST215
D1Racing Lightweight Chromoly Flywheels are made from 4140 one-piece billet chromoly steel.
They are specifically designed to reduce weight and inertia for better engine response.
Most incorporate special design features to enhance the air flow to improve the cooling of the clutch. The ring gear teeth are milled onto the flywheel unlike an aluminum flywheel where the ring gear is pressed onto the flywheel which has the possibility of separating from the flywheel.
All D1Racing Chromoly flywheels have passed engineering tests to 12,000 rpm. After professionally installed the flywheel requires a 1000 km break-in period.
Ultra heavy-duty and weighs only 11.4 lbs (Factory flywheel weighs 23 lbs)
Meets or exceeds SFI 1.1 specification
Made from 4140 forged chromoly steel (2X stronger than billet steel)
D1Racing Lightweight Chromoly flywheels incorporate special design features to enhance the airflow for improved clutch cooling
i want to upgrade to the bigger 3sgte flywheel for a better choice in clutch
AE85
gen4 3sgte
w55 gearbox.
