the loom and ecu fits fine, but the other 4 plugs i am having problem i need to rewire the plug some how.
colour og the plug from the loom <black,2 white, blue plug.
PLEASE HELP>>>
Bazda wrote:that information doesnt help.
Where is the plug. What did it plug into before. Pictures will prob be the best.
BZG|Bling wrote:Have you worked out what each wire is by using the ECU pinouts of the 4age ECU and the 4afe ECU, then compared? Are the ones you plugged in all the exact same?
I would just be surprised if they all matched up, so wondering if you worked it out or not.
touge_ae101 wrote:BZG|Bling wrote:Have you worked out what each wire is by using the ECU pinouts of the 4age ECU and the 4afe ECU, then compared? Are the ones you plugged in all the exact same?
its not for the ecu plugs, its for the body loom. power for all the heaters, dash etc.
they should all match up as you are putting a ae111 motor in a ae111 body. there should be 4 plugs already there and its just a matter of matching up the colours/sizes (should get you pretty close anyway)
oh hold up are you putting a silvertop loom in aren't you? if so you are $&#$% as with ae101, body loom wires are all routed differently. might be easier to alter your old 4afe loom.
gasman wrote:weren't you going from a auto to a manual? if that's the case then you could almost disregard one of those plugs already.
