Bosch 044 install tips please.
Postby BlakeNZ » Mon Aug 16, 2010 7:50 am
If i am installing a 044 intank on a soarer, will i need to upgrade the wiring or add a relay, or will the current draw be similar to the present walbro 341 that is in there?
BlakeNZ
Postby Heylin » Mon Aug 16, 2010 1:57 pm
I had a SARD 280LPH pump installed to MR2 and they used the stock wiring. I suppose if your wiring is deteriorated then yeah.
Heylin
Heylin
Postby Py7h0n » Tue Aug 17, 2010 3:34 pm
044 draws a lot more than a Walbro. It would be best to run seperate wiring triggered by a relay off the factory wiring.
Py7h0n
Users browsing this forum: Bing [Bot], Google [Bot] and 19 guests
