I have started to chuck a blue top together to put back in so that I might be able to get some use out of the car while Im building a new motor.
Im going to stick with the same 16v head I had on the boosted engine with the same injectors (395cc), CAS and Link computer.
Other than the small exhaust issue the only other issue is that the tune in the V5 Link is for the turbo motor.
I figure the car should start and run with no issues but not sure if it will be ok to drive as far as ignition timing is concerned?
Im guessing the performance would be pretty average??
