OH NOES!!!!! Radiator Foam
Postby blindnz » Mon Aug 30, 2010 1:21 pm
since replacing the heater core in the girlfriends ae92 levin i am getting but loads of foam out of the radiator.
the car hasnt gone anywhere, is this just air bubbles? when i first filled it i didnt fill the heater core first. i've since drained it and used a piece of tube to fill the heater core. and then refilled the radiator.
But im still getting all this foam as soon as i start the car. I had it running for about 5 minutes pouring water in to wash the foam off and its still foaming.
Never had it like this before, even in my old trueno changing radiators replacing head gaskets i havent seen it like this.
blindnz
foam
Postby panda_dan » Mon Aug 30, 2010 2:31 pm
Hi there blindnz. Is it possible that you grabbed the detergent instead of the coolant?
panda_dan
Postby blindnz » Mon Aug 30, 2010 2:49 pm
Nah its straight water at the moment, no coolant. i just wonder if the guy i bought the heater off cleaned it out at all. although i ran a hose through it when i bought it and the water ran out clean.
It does almost seem like detergent foam.
Cheers Rob.
blindnz
Postby AE92-5ONIC » Mon Aug 30, 2010 3:00 pm
Did a quick search on google, and this is the only thing I can really find
mine did the same thing when i put new radiator in. it was i white foam like an orange julius drink if you are familiar with those. i had to keep skimming the top with shop vac untill clear. i think it was residue in radiator eventually it cleared up
Appart from that, just HG problems, but yours doesn't look like a cracked HG.
AE92-5ONIC
Postby blindnz » Mon Aug 30, 2010 3:10 pm
Yeah its crazy. Wouldnt think it had a BHG (Hence the OH NOES!!) As theres no water in the oil and the water and foam is clear. Wasnt over heating or anything when it was parked up. I Just didnt want to keep it running because i was worried about the foam churning up and leaving airbubbles every where.
blindnz
Postby 79rolla » Mon Aug 30, 2010 3:45 pm
give the cooling system a good flush with the motor running (hose in heater hose) and clean any residue out and see if it still does it, it could have had some engine flush in it.
past: AE82 FXGT
79rolla
Postby CAMB01 » Mon Aug 30, 2010 4:43 pm
Steve will tell you, you have a blown headgasket :roll:
1993 Mitsubishi EVO 1 Racecar
1989 AE91 FX-ZS (Previous)
Custom Works Automotive
http://www.HCCC.org.nz
CAMB01
Postby Quint » Mon Aug 30, 2010 4:47 pm
Nah, it's not a 7m.
Quint
Postby MAGN1T » Mon Aug 30, 2010 5:17 pm
I don't need to because Cambo knows.
Steve
Computers make you go mad.
MAGN1T
!USER HAS BEEN BANNED!
Postby tsoob » Mon Aug 30, 2010 5:18 pm
looks like soap of some kind, you tried to flush the crap out of it then starting again?
and yeah those heater cores are GAY to bleed.
Platinum Wheels
15 Parkway Drive
Mairangi Bay
09 486 5317
WHEELS, TYRES & SUSPENSION!
www.platinumwheels.co.nz
tsoob
Postby rollaholic » Mon Aug 30, 2010 9:16 pm
have ya got the heater set to hot?
Postby MAGN1T » Mon Aug 30, 2010 9:35 pm
Just leave your motor running until the bubbles stop coming out. They can't keep coming out for ever , can they?
Steve
MAGN1T
Postby CAMB01 » Mon Aug 30, 2010 9:40 pm
Just winding ya up Steve.
Ive seen it before when fitting new radiators. Just have to keep flushing it till it stops.
CAMB01
Postby MAGN1T » Mon Aug 30, 2010 9:43 pm
CAMB01 wrote:Just winding ya up Steve.
You mean when you fit a new radiator along with a bottle of chemiweld to a car with a leaking headgasket.
Good motors don't pop radiators.
Have you put any thought into why the heater failed?
Steve
MAGN1T
Postby sergei » Mon Aug 30, 2010 10:23 pm
Steve
Radiators have lifetime expectancy. There is temperature and vibration involved (and chemical factors). They can't last forever. In fact most of plastic radiators will last ~10 year or so on average. It does not mean it has blown head gasket. Normally BHG happens after radiator failed (and/or waterpump) due to obvious reasons. It does not make sense for for BHG to happen then after couple of years radiator to fail. When head gasket is blown it is like metastasis patient - you have limited time before it becomes huge problem. Pressure is only a problem when the cap is jammed.
Postby MAGN1T » Mon Aug 30, 2010 11:46 pm
sergei wrote: Pressure is only a problem when the cap is jammed.
Or when there's more gas getting into the cooling system than the vent is capable of venting and the pressure rises.
Of course it's a total no brainer to test it with a pressure gauge. That's what removes all the BS.
Steve
MAGN1T
Postby CAMB01 » Tue Aug 31, 2010 8:08 pm
What makes you such a so called expert at blown head gaskets Steve?
CAMB01
Postby Lloyd » Tue Aug 31, 2010 9:28 pm
Put the cap on, drive around the block a couple of times, let it cool down, top it up, go for a drive and check it when its cold again. If its not overheating and not using water then it'll be right
Postby Mr Revhead » Tue Aug 31, 2010 10:14 pm
CAMB01 wrote:What makes you such a so called expert at blown head gaskets Steve?
Owning lots of Mitsis? :P
Postby MAGN1T » Tue Aug 31, 2010 11:31 pm
Playing for turbos for too long and putting over 200,000Ks on a townace by driving it over the wainui hill at least once a day over a period of 12 years.
Have you read my turbo V8 build on NZV8?
Steve
MAGN1T
