nissan cefiro boot not opening
Postby gleem » Fri Sep 03, 2010 10:37 am
1990 a31 cefiro boot jammed. When i put the lever i can here somthing clicking in the boot so lever is not the issue. I dont have the key for the boot either. If i get inside through the back seats, can i do something? or if i get a screw driver and hammer it into the lock?
Ive pushed it up and down etc to try and free everything but no luck
gleem
Postby Quint » Fri Sep 03, 2010 10:52 am
Get someone to try and open the boot, WHILE you're pulling the popper.
Otherwise if you can remove the interior of the boot while being in the boot. you could unbolt the lock from the boot. (depending on how is made etc. etc.)
Quint
Postby iOnic » Fri Sep 03, 2010 1:23 pm
Get in the boot and pull the cable/release the latch manually?
Postby gleem » Fri Sep 03, 2010 2:57 pm
tried the 2 person thing. ill have to get in the boot. May not make it alive with the petrol fumes in there lol
gleem
Users browsing this forum: Bing [Bot], Google [Bot] and 17 guests
