1JZ Map sensor variants
Postby jeda teach » Sat Sep 04, 2010 3:56 pm
Missing the Map sensor on my 1JZ-GE engine. Are there any other toyotas that share the same Map sensor ? Can i adapt another one to suit of do i have to use the original sensor for that engine.
jeda teach
Postby MrOizo » Sat Sep 04, 2010 4:29 pm
common mod is a 2JZ MAP sensor so that might be something to look for?
MrOizo
Toyspeed Legend
Postby jeda teach » Sun Sep 05, 2010 11:19 am
I guess i was hoping to find something at pick a part. JZ powered cars d not pop up very often there.
jeda teach
Postby BlakeNZ » Wed Sep 08, 2010 12:24 pm
ring toyota and see if you can get a part number, so we can see if it is the same as the turbo JZ motors. With the jzge being N/A, i would imagine they are different.
BlakeNZ
Postby sergei » Wed Sep 08, 2010 12:52 pm
2JZGTE has different part number to 1JZGTE (twin turbo) for MAP sensor.
Non turbo also has different part number.
As far as I know 1JZGTE single turbo does not have map sensor at all (I might be wrong here).
Have a look here http://www.toyodiy.com/
