3sfe idle too high
3sfe idle too high
Postby GT101 » Thu Sep 16, 2010 4:12 pm
purchased me a st191 nz assembled 96 corona with a 3sfe :roll: for 2g
since ive had the car sits at 1200rpm at idle and ive tried all the usual things like the screw/bolt on the throttlebody etc and checked the fuses , reset the computer.
still cant seem to find out whys its sitting that high
also just did the thermostat and when the temp gets up the fan ins't kicking in.
i thought it was stuck in cold start mode because of the faulty thermostat
anyone got any ideas or had similar issues?
current :project cynos version 2
previous toyotas :93 ae101 sprinter gt sedan 20v, 93 gt starlet,el44 cynos alpha,ae101 trueno.....
GT101
Postby .:O4AGTZ:. » Thu Sep 16, 2010 4:46 pm
Maybe we could swap some idleage, my idles low
.:O4AGTZ:.
Postby rollaholic » Thu Sep 16, 2010 4:47 pm
could be stuck in cold start cos the temp sender is not so good. is your fan getting power?
Postby XS1V » Thu Sep 16, 2010 5:04 pm
For idle high check for vacuum leaks by spraying a can of brake clean or similar around the manifold and intake etc and if it idles up it is sucking it in.
Idle low is normally a setting with either TPS or AFM (if fitted). How low is low though?
Brad
ST205 Group A Rallye #2363
XS1V
Postby GT101 » Thu Sep 16, 2010 6:37 pm
just checked the power going to the fan and theres no power getting to it
and i think the temp sensor is getting none aswell
so i can replace the temp sensor but what about the power to the fan plug problem?
i checked the fuse and it looks ok , spose it could still be faulty?
GT101
Postby XS1V » Fri Sep 17, 2010 11:43 am
There will be no power getting to the fan untill the temp sensor at the radiator tells the relay to switch on the fans. To test the circuit you want to make sure on of the pins to the fan has a constant earth and the other connects to one of the pins on the fan relay in the fusebox. Also make sure the relay is working and there is power getting to the relay. There should be four pins on the relay, one will be 12V with ignition on coming from the fan fuse, one full time power (may be ignition supplied also), one going to the fan plug as mentioned above and the other going to the temp switch on the radiator. If you remove the ground signal on the wire going to the fan switch it should close/click the relay and put power on the wire going to the fan. Hope that makes sense. 8)
The radiator fan sensor will have ground going into it and the other pin will connect to the fan relay with a ground signal at all times until it gets to hot at which time there will be no ground signal to the relay and the fans will come on.
The engine temp sensor should have no power going to it at all. One wire is a full time ground normally from the intake manifold and the other is the signal wire to the ECU. :)
Brad
XS1V
Postby sergei » Fri Sep 17, 2010 12:07 pm
XS1V wrote:There will be no power getting to the fan untill the temp sensor at the radiator tells the relay to switch on the fans. To test the circuit you want to make sure on of the pins to the fan has a constant earth and the other connects to one of the pins on the fan relay in the fusebox. Also make sure the relay is working and there is power getting to the relay. There should be four pins on the relay, one will be 12V with ignition on coming from the fan fuse, one full time power (may be ignition supplied also), one going to the fan plug as mentioned above and the other going to the temp switch on the radiator. If you put a ground on the wire going to the fan switch it should close/click the relay and put power on the wire going to the fan. Hope that makes sense. 8)
The temp sensor should have no power going to it at all. One wire is a full time ground normally from the intake manifold and the other is the signal wire to the ECU. :)
Brad
I would like to make a correction:
Fan switch relay is always on when there is ignition (you can feel it being hot), it uses "Open when relay ON, Closed when relay OFF" contacts to drive the fan.
When you disconnect the ground from relay coil (what Temp switch does when it reaches certain temperature) the relay turns off and closing the fan contacts.
It is done this way because of failsafe, if temperature switch wire is permanently disconnected the fan will be always on, also to allow pressure switch from A/C system to be in series of the circuit to turn on the fan whenever it disconnects it.
Postby XS1V » Fri Sep 17, 2010 12:17 pm
100% correct as always 8) Have edited above post to include what i missed.
Brad
XS1V
Postby GT101 » Fri Sep 17, 2010 3:13 pm
Sweet cheers for the info once again guys
was just talking to a friend about testing the relay last night.
will give it a go tonight in the shelter of my garage as its getting a tad windy around here.
GT101
