iOnic wrote:How much boost was it making and how laggy was it to get there? Cars can make full boost with a lazy wastegate - it just takes longer to get there. Most wastegates are slightly open well before you reach full boost. If it's making full boost but is slow then it could be that the actual engine is low on compression? This could also explain the lag...
If it sounds like that then it's definitely well goneJust out of curiosity why is she still interested in the car if she knows that it'll need mechanical repairs? Is it ridiculously cheap or something?
Budget depends on how much you can get the turbo for and where you take it. We did a turbo replacement on an R33 at work (similar setup) and it came to just under $1k but almost half that was the cost of the turbo.
iOnic wrote:Might pay to ring Carl Ruitermann or pay E&H a visit to see if he knows anything about the car. By the sound of things it'll need a replacement turbo regardless of whether it's the main fault or not. What were the compression test results?
You get people like that a lot on trademe. "Nah bro it's mint I took it to a shop and they said it's mint"
GT101 wrote:ive driven a fair few skylines with dodgy turbos and most times it sounds like its making boost but nothing much is happening.
the price of the car would be the selling point i guess.
these days i cant believe how much ppl are selling early 90's rwd nissans for.
Luke - BZG wrote:Is it running a stock boost gauge?
Some stock boost gauges are electronic and instead of measuring actual boost pressure they monitor the function of the compressor and estimate its boost output (Supra and GTO do this)
So if the compressor blade is rooted it would still display normal boost.
Just a thought.
Users browsing this forum: Bing [Bot], Google [Bot] and 18 guests
