ST 205 brakes
ST 205 brakes
Postby Anth_555 » Sat Sep 25, 2010 9:18 pm
ok so ive gone to 5x114 and the stock rotors can not be redrild to the new PCD as they wont fit over the hub flange. the plan was to use supra rotors and have brekets for the calipers made but there is no room to move them round. so the calipers have to stay where they are. can you get 2 peice rotors in 315mm? or is there a 4pot caliper witha smaller bolt hole distance? or any other ideas?
-1994 GT4 Celica ST205 project
-1984 Trueno AE85
-1993 Surf LN130
Anth_555
Postby Malcolm » Sat Sep 25, 2010 9:20 pm
have you had a look through a brake disk catalogue? I found an EBC one online that had dimensions for most production cars, and used it to find suitable disks for my conversion
Postby Prymal » Sun Sep 26, 2010 6:45 pm
wait a sec - 5x114 ? how did you go about that , im curious
St205 NZ New Group A WRC Gt4- Accept no Imitations !
Prymal
Postby DeeCee » Sun Sep 26, 2010 8:32 pm
I'm sure Ant's was talking about Rav4 hubs previously
GT Four Adovansu
DeeCee
Postby Bazda » Sun Sep 26, 2010 9:42 pm
There are no rotors in the catalog that are the same as the ST205 brake discs. The size is abnormal as its 315mm. The height is fairly deep at 59mm.
Majority of other dics over the 300mm mark are either a shallow height or when you get into the Dodge viper and Ferrari stuff the heights are like 70-80mm+.
2 piece rotors I got a quote for a DBA and it was like nearly $700 for a pair.
You would be better off buying Wilwood calipers and making them fit!
Also you wont get any other discs to fit the st205 caliper as the surface of the brake pad is quite wide, meaning if you stepped up to a bigger PCD the inner circle of the disc will become bigger and this inner part will hit the caliper. But I could be wrong. You would need to try it out.
Postby thegreatestben » Sun Sep 26, 2010 9:51 pm
You should be able to get a fair bit of coin selling the celica ones if you had to go that way as well. Should offset the cost of new bits nicely :)
thegreatestben
Postby strx7 » Sun Sep 26, 2010 10:11 pm
go to 18inch rims and put some DBA2808's on it
or go to 17's and run JZA80 front 323mm discs. or look late model STi 325mm front discs
Postby Anth_555 » Sat Oct 02, 2010 4:50 pm
problem solved i have converted factory rotors to two piece. for some pics it will be on my build thread
-1984 Trueno AE85
-1993 Surf LN130
Anth_555
Postby Bazda » Sat Oct 02, 2010 5:54 pm
Anth_555 wrote:problem solved i have converted factory rotors to two piece. for some pics it will be on my build thread
I had issues when I mounted my hats directly to stock discs. The hats would grow at a faster rate than the disc due to it being aluminium. Therefore cracking the discs where the hat mounted to it.
Had to slot where the bolts went through, make all these little spacers so it would hold the hat off the disc xx thou which allowed the hat to grow and not crack the disc.
But that was for racing. For the road you prob should be ok :)
Nice work.
Postby Anth_555 » Sat Oct 02, 2010 6:28 pm
i plan to use it for racing when its up and going again. but these are made from mild steal so i shouldnt run it to that problem
-1984 Trueno AE85
-1993 Surf LN130
Anth_555
Postby Bazda » Sat Oct 02, 2010 9:04 pm
Anth_555 wrote:i plan to use it for racing when its up and going again. but these are made from mild steal so i shouldnt run it to that problem
You should be fine with mild steel!
Postby wde_bdy » Sat Oct 02, 2010 9:41 pm
Celsior/LS400 run a 315mm disc, might be worth hitting the Brembo catalogue to see how it compares. Have a set on my KE70 with the matching 4 pot calipers.
Callum
wde_bdy
Postby Bazda » Sat Oct 02, 2010 9:54 pm
wde_bdy wrote:Celsior/LS400 run a 315mm disc, might be worth hitting the Brembo catalogue to see how it compares. Have a set on my KE70 with the matching 4 pot calipers.
Callum
But is only 28mm wide.
The Celica calipers are made for 32mm wide discs. 30mm would be the minimum I would go.
Postby wde_bdy » Sat Oct 02, 2010 11:03 pm
And it's not a big problem to fit a spacer behind the pads, assuming you don't want the work/cost involved in going to two piece rotors.
Callum
wde_bdy
Postby Anth_555 » Sun Oct 03, 2010 2:50 am
celica rotors are 30 min 28 mm like supra . Celsior/LS400 run 28mm min 26mm. also the offset of the disc is out by 4mm so they cant be used and they have no where near the venting the celica rotors do
-1984 Trueno AE85
-1993 Surf LN130
Anth_555
Postby ®usty » Sun Oct 03, 2010 7:42 pm
thought about Cadillac Catera discs, people were researching cheaper alternatives for brakes for 6gen celicas?
®usty
Users browsing this forum: Google [Bot] and 17 guests
