KYB or OEM Toyota struts?
Postby nile » Sat Oct 02, 2010 3:50 pm
I can't decide between getting the OEM Toyota FXGT (ae82) struts, or the KYB twin tube gas ones (R-332021 F-365041). I am also wondering if they are the same part? The KYB set is around $200 dearer than the OEM ones at the prices I get (account at Toyota but not at SCA)
Can anyone here shed some light in any difference between the two, and which would be best?
nile
Postby MR2BOY23 » Sat Oct 02, 2010 4:26 pm
AFAIK KYB are factory eequivelant, so there should be no difference. But I could be wrong :P
MR2BOY23
Postby metal_sean_head » Sat Oct 02, 2010 4:29 pm
Is this just for a daily street driven vehicle? If so, i would just go with the OEM ones. You prob won't be able to tell much of a difference if any.
VTEC: All of the lag and none of the boost.
89 AE92 FXGT
Big Port Redtop
TVIS!
19.8@32kph
metal_sean_head
Postby nile » Sat Oct 02, 2010 9:02 pm
Yeah daily driver as well as an entry level car for clubsport (autox/motokhana). I was looking at doing the Koni thing but decided to keep this car on the cheapish side of things and just get a better car sooner. I will be looking into getting some new springs made up too.
nile
Postby Mr Revhead » Sun Oct 03, 2010 8:02 am
Go genuine.
The kybs will be generic corolla ones. Genuine will have specific fxgt valving.
They are not the same.
Postby nile » Sun Oct 03, 2010 9:25 am
Mr Revhead wrote:Go genuine.
That's what I initially thought but KYB have a different part listed for the "GT compact 16V" which I assume would be a stiffer strut?
I'm leaning to genuine because it seems like at worst it'll be the same part as the KYB.
nile
Postby Mr Revhead » Sun Oct 03, 2010 10:47 am
Oh do they now? That might be worth looking into then, then never used too. see if you can find some specs. Stocks should be able to tell you the difference between the stock KYB and the GT one. That said they I doubt they will be better than genuine and $200....
I wonder what it would cost to get some dyno'd....
Postby nile » Sun Oct 03, 2010 11:54 am
Do you know where Stocks are? I emailed them about the koni inserts - no reply, and I went looking for their shop and couldn't find it, they've just updated their website with the new address - doh!
nile
Postby Mr Revhead » Sun Oct 03, 2010 12:11 pm
Where are you?
Postby MR2BOY23 » Sun Oct 03, 2010 1:04 pm
Off Carbine road in Mt Welly
Te Apunga
MR2BOY23
Postby nile » Tue Oct 05, 2010 4:39 pm
Mr Revhead wrote:Where are you?
I'm in Wellington, was looking in Petone.
nile
Users browsing this forum: Bing [Bot], Google [Bot] and 18 guests
