R154 Remote shift
R154 Remote shift
Postby Jebus » Mon Oct 11, 2010 9:51 am
Is it possible to take an older non-remote R154 and switch the rear case/remote shifter from a jzx100 onto it?
Jebus
Postby edwagon » Mon Oct 11, 2010 11:02 am
It is possible on the w58s etc, it swaps straight over same as swapping shifter positions - the only problem is that the bottom brackets for the remote shifter cage thing are missing from the rear housing of a non remote box, they are kinda needed but easy to make up and alloy weld, or build into box mount.
Hopefully same story for r154!
edwagon
Postby Jebus » Mon Oct 11, 2010 11:07 am
We have the whole rear housing that we can swap. hopefully its straight forward.
Mel broke her R154 at taupo
Jebus
Re: R154 Remote shift
Postby FLAWLES » Mon Oct 11, 2010 7:45 pm
Jebus wrote:Is it possible to take an older non-remote R154 and switch the rear case/remote shifter from a jzx100 onto it?
wow
i was thinking this exact thing the other day
remote shift r154s are not cheap!!!
FLAWLES
Postby escortman » Mon Oct 11, 2010 9:11 pm
i think from memory theres a bearing or something that slight diff in size
4x4 toyota blizzard offroader
escortman
Postby escortman » Tue Oct 12, 2010 7:15 am
o no wait forget that this was on a w58
escortman
Postby Jebus » Tue Oct 12, 2010 4:01 pm
After a bit of itnernet reading, im pretty sure nearly all of the rear housings and shifters interchange.
Except some earlier ones have slightly different bolt patterns on top.
Jebus
