whynot wrote:the ecu problem was only a problem in the earlier models say around the early 90's so if you have a bzg or bzr it should be fine
matt dunn wrote:whynot wrote:the ecu problem was only a problem in the earlier models say around the early 90's so if you have a bzg or bzr it should be fine
Yeah AE101 only with that fault.
rolla_fxgt wrote:matt dunn wrote:whynot wrote:the ecu problem was only a problem in the earlier models say around the early 90's so if you have a bzg or bzr it should be fine
It was just cause Toyota didn't want to make a perfect car that they made them leak.
FANGIN wrote:Actually, while on this topic...
I have a little bit of a problem with my AE111, it's done it since I've had it.
Start it from dead cold, runs fine (like any injected car should). However, if I drive it a short distance and turn it off before it gets fully warm, then restart it, it "bogs". Still drives fine under light throttle, but if you want to give it any more than say 1/4 throttle, it just doesn't want to move.
I usually just start it, let it idle for a minute, then drive off normally & the problem isn't there. It's like the car thinks that it is still cold when it is halfway to normal operating temp.
touge_ae101 wrote:FANGIN wrote:Actually, while on this topic...
my guess would be the ecu water temp sensor or possibly the oxy sensor. more likely water temp though. changed mine and it made a huge difference!
BZG|Bling wrote:Done the simple things like plugs / leads etc?
