Brakes not releasing pressure (locking on).
Postby Quint » Fri Oct 15, 2010 8:56 am
Still having fun with my brakes, only thing holding me back from the WOF.
background:
viewtopic.php?t=80970&highlight=
Honed and replaced the seals in the master. Got pedal and brakes. But now after using the brakes heavily they'll stick on, they'll get heavier and heavier until the car is really dragging and I have to pull over and release the pressure off the callipers.
I've put a spacer(gasket) between the master and the booster hoping it'd fix the problem. Nope. Do I need a thicker gasket?
Running out of ideas (and time!) Need to fix them to get a WOF next week for MM. Anyone know what's causing this?
edit: proportioning valve may be the culprit. Anyway to check them?
Quint
Postby CAMB01 » Fri Oct 15, 2010 9:47 am
What did you use to lube up the new seals in the master when you put it back together?
1993 Mitsubishi EVO 1 Racecar
1989 AE91 FX-ZS (Previous)
Custom Works Automotive
http://www.HCCC.org.nz
CAMB01
Postby Quint » Fri Oct 15, 2010 11:05 am
I used brake fluid.
Quint
Re: Brakes not releasing pressure (locking on).
Postby allencr » Fri Oct 15, 2010 11:31 am
Quint wrote:...the car is really dragging and I have to pull over and release the pressure off the callipers. I've put a spacer(gasket) between the master and the booster hoping it'd fix the problem. Nope. Do I need a thicker gasket?
Yeah, an extra gasket might do it but you'd be better off if you just adjust the booster's rod back a bit.
You could use a very fine wire VERY softly to figure out when the seals start to cover the ports, or you can measure the difference between where the piston sits & how far the rod sticks out of the booster.
They can usually use a little pre-load so you aren't spending too much pedal travel pushing fluid back into the reservoir. Your problem is too much.
allencr
Postby MAGN1T » Fri Oct 15, 2010 1:12 pm
Flexible rubber hoses get blocked from time to time. Will give those symptoms.
Have you lifted the car to see if all the brakes are stuck , or just one?
Modifications don't work if it's broken.
Steve
Computers make you go mad.
MAGN1T
!USER HAS BEEN BANNED!
Postby whynot » Fri Oct 15, 2010 8:02 pm
just to clarify. Is it all 4 brakes binding?
when they are playing up have you released the pressure at the brake or at the master cylinder?
whynot
Postby matt dunn » Fri Oct 15, 2010 9:24 pm
Quint wrote: I have to pull over and release the pressure off the callipers.
How are you doing that? Opening a bleeder?
Does fluid squirt out under pressure?
When it does it next crack the line at the master cyl instead of the bleeder,
that will tell you if it the M/C holding the pressure or something in the lines/bias valve/hoses etc etc
Postby Quint » Sun Oct 17, 2010 8:56 am
Was bleeding it at the calliper.
Found the problem, The primary return port on the master cylinder was blocked by the return seal. The seal I was sold was ~1.5mm too long so was covering the port not allowing the fluid to return. So only one set of brakes were binding up (front right and rear left) but the secondary would balance the other two to lock up the same.
Lesson: when rebuilding the master, once you've rebuilt it, blow through the line fittings on the side of the cylinder when it is at rest and see if you can hear air coming out of your return ports (pin hole sized). If you can't they are blocked (dirty) or the seal is wrong.
Side note: Weighed the ga70 in, 1410kg. aw11 came to 980.
Cheers for the help guys.
Quint
Postby whynot » Sun Oct 17, 2010 1:20 pm
we had issues with the return port on the old mans bike brakes. it had never been drilled out at the factory! took a while to figure that one out
whynot
