ST/BT into 4afe AE101 Corolla HB
Postby spoonza6 » Sat Oct 16, 2010 8:33 pm
right, i did a search and it was pretty limited
i have a 93 Toyota Corolla GT 4afe powered
i want to drop a 20v 4age in and
so far i know a BT or ST with gearbox will bolt up no problems
with all the loom and ecu available
would the integration of the loom be the only fiddly bit to do?
spoonza6
Postby tsoob » Sat Oct 16, 2010 11:50 pm
are the mounts the same?
your gauges and that will be a c**t
Platinum Wheels
15 Parkway Drive
Mairangi Bay
09 486 5317
WHEELS, TYRES & SUSPENSION!
www.platinumwheels.co.nz
tsoob
Postby spoonza6 » Sun Oct 17, 2010 5:35 am
fu'd this one up.
spoonza6
well after doing a search on here, and the results were years old people said they were the same
if anyone has an idea on whats exactly needed in doing this conversion please feel free to steer me in the right direction
car belongs to my sister and i wanna give it more kick (while shes away in australia of course haha)
currently being fully paneled and going to be resprayed, will put some pics up next week
spoonza6
Postby KinLoud » Sun Oct 17, 2010 7:58 am
Hi - I put a silvertop 20v into a 4afe AE101 marino
Silvertop loom and computer plugged straight into the body loom.
Only thing I had to do was join the fuel pump control wire from the silvertop air flow meter (afm) to the body loom.
The 4afe computer controls the fuel pump VS afm in the silvertop setup.
The blacktop will be a better/newer option but you will have to do a lot more to get it running as it won't plug and play like the silvertop
KinLoud wrote:Bought a damaged 1992 AE101 Trueno 4age 20v silvertop C52 gearbox
Bought an AE101 Marino 4afe C50 that had a seized engine.
We (me and Ewan, 10k20v) bolted the whole front subframe and suspension from the Trueno into the Marino (brakes, suspension, gearbox and motor) also swapped the brake booster and bias valve.
Also swapped the rear brake,s handbrake cables, hubs and swaybar across. Should have swapped the steering rack so the 20v steering vacuum lines had somewhere to plug into (it runs fine with these lines just blocked off!).
The 20v engine loom plugged straight into the Marino body loom. There was even an unused plug on the Marino loom just waiting to plug into the 20v aircon idle up valve!!!
Only wiring needed was a jumper wire from the 20v loom to the fuel pump relay wiring so the pump worked correctly.
Easy! But sure helps to have the complete donor vehicle!
Total cost $1200!!!!! for everything including the cars!
Big brakes and cert next.
Ken
Postby touge_ae101 » Sun Oct 17, 2010 11:21 am
depends what you are after. i put a blacktop in my ae101 trueno. was a bit tricky wiring it up as the wiring for the body loom to the fusebox is different in ae111 & ae101 series cars. ended up re-wiring the fusebox (i had help from a mate whos pretty clued up electrically). also found we had to add in a starter relay and run a few extra wires.
if you are after a bit more go for a daily and an easy swap, do the ST as it plugs straight in if you use the silvertop loom. (maybe 5-6 wires need to resolder)
but if you are after a little bit more go than a ST and all the other benefits of a BT, it might be worth the extra wiring effort. it only took us probably a total of a day or so to do the wiring (normally worked for 45min stints before our wed meet :lol: )
touge_ae101
Postby soopachargen » Sun Oct 17, 2010 11:24 am
if you use a silvertop loom in with the blacktop you just run the IAT sensor and map sensor off the afm wires and change some wires at the computer, its probably easier than wiring in a blacktop loom, and all plugs up to the engine
When in doubt, down and out.
soopachargen
Postby spoonza6 » Sun Oct 17, 2010 11:37 am
would really like to put a blacktop in but got to consider finding one first and its jus to give it a bit more pep
will start huntin for a silvertop gb ecu and loom and then try work it out from there
cheers peoples
spoonza6
Postby touge_ae101 » Sun Oct 17, 2010 12:10 pm
this would be a fantastic buy. reasonably priced too. you could find one cheaper but sometimes its worth paying a little more and having a little bit of piece of mind. will def be wanting the LSD box as well! :lol:
viewtopic.php?t=81035
touge_ae101
Postby soopachargen » Sun Oct 17, 2010 12:12 pm
id say for what you get thats very cheap, id almost consider it as a spares package
soopachargen
