black top exhaust
black top exhaust
Postby tim_blair » Fri Oct 29, 2010 5:38 pm
i fabed up a new exhaust for my black top
i all ready had 2.5 from the rear to the cat and it was standed from the cat to the engine
what i have done is remove the cat and go with 2.5 all the way to the turbo outlet
my question is: there is a sensor after the cat, what is this sensor? and should it still be in the exhaust now that the cat is removed?
i currently have the sensor in
girl: can I trust you?
me: you can trust anything :D
tim_blair
Postby sergei » Fri Oct 29, 2010 5:50 pm
That sensor is cat. overheat sensor. Not needed if you don't have cat.
You can remove it and jump the plug (so there will not be light on dash complaining about it).
Postby Lurkin » Fri Oct 29, 2010 8:14 pm
could be very keen to buy the factory exhaust if you still have it and it is unmolested....
Past casualties
1986 4age liftback (sold)
Lurkin
Postby tim_blair » Fri Oct 29, 2010 11:20 pm
kool ill remove that sensor
also yea the exhaust is in good condition except the flange for the cat has been nicely cut off
i can eaisly weld it back on for you
also i have cut off the mounts for the 02 sensor and the cat sensor mentioned earlier
i can weld the cat sensor mount back on and cut a new thread for an 02 sensor too
tim_blair
Postby Lurkin » Sat Oct 30, 2010 12:00 pm
I'm looking for everything other than the 2-1 pipe + extractors...
Past casualties
Lurkin
Postby tim_blair » Sat Oct 30, 2010 5:39 pm
all i have is the extractors
2>1 pipe and the cat
tim_blair
