Tagged wrote:this is all I know so far;
- engine oil change
- oil filter change
- air filter change
- power steering fluid change
here are my questions;
1. how are the above done?
-oil change: there are a ton of guides on this everywhere, just do a google search
-oil filter change: unscrew the old one off, spread a little new oil around the rubber seal on the new filter, screw the new filter back on and add however many turns it says to on the filter after it has contacted the filter mounting surface
-air filter change: very self-explanatory - take out the old one, chuck the new one in.
power steer fluid: no idea, ask someone else![]()
2. what tools I would need?
-oil change: whatever socket to get the sump plug off, along with a breaker bar or maybe ratchet
-oil filter: may need a filter wrench, otherwise just use your hands
-air filter: hands
3. does a pod filter needs changing?
-usually, they still filter the air and still get clogged up, the exception is the cleanable filters that use an oil to trap the dust (usually K&N filters?), these just need to be cleaned every now and then, not changed.
4. what engine oil is recommended for a BZR; I know lower viscosity is better for 4A-GE engines, so 5W10, 5W15?, what brand and how many liters?
- I don't think I've ever seen a car use a 10 or 15 grade oil, you need something more around the 40's (so something like castrol magnatec 10W-40 should be fine), someone else can also chime in here if there is a better oil for the BZR![]()
5. what kind of oil filter?
Go with a Toyota filter, guaranteed to be better than any of the Fram/Ryco/Repco filters, remember, Toyota designed your car, they know how to make a good oil filter for it.![]()
6. and what other things needs to be done in a service?
Depends how far you want to go, there are a bunch of things that should be done, but many require different intervals. For example I would reccommend changing engine oil every 5000kms, whereas transmission oil can be changed up to 50,000kms down the line (I think?).
7. an auto requires auto-transmission fluid change, what about manuals?
Yes, manuals still have to use a lubricant (oil), just as auto's do, the interval change is roughly the same.
9. lastly, wheres the best place to buy everything I need for this?
Oil filter - Toyota
Oil - Repco/Supercheap
Air Filter - Also Toyota, don't fall for the K&N filter guff, it's proven they let more dirt into your engine than a stock paper filter.
Thanks guys!
h8wrxs wrote:most people seem to think magnatec is crap oil....
dont know what to recommend though
Snaps wrote:Air Filter - Also Toyota, don't fall for the K&N filter guff, it's proven they let more dirt into your engine than a stock paper filter.
BZG|Bling wrote:h8wrxs wrote:most people seem to think magnatec is crap oil....
Careful there, i've seen a lot more people using Magnatec without problem compared to the number of people that make claims its a crap oil.![]()
Don't believe everything you read on the net.
solitaire wrote:Snaps wrote:Air Filter - Also Toyota, don't fall for the K&N filter guff, it's proven they let more dirt into your engine than a stock paper filter.
Bugger, i run k&n's because i hate buying new filters and throwing the old ones away! has not done any harm to my engines (yet) but sad to hear that - do you have any links to the study?
Message: I worked for race teams for years. One Toyota Atlantic team I worked on the driver thought the car was losing power from the start of a race to the end. So we did leak down checks when we got new engines in. 3% leak down- New. At the end of a race we checked it again and we got 29% leak down. So we sent the head to get the valves done and checked the leak down when the head returned. 4%- Leak down. At the end of the next race 31%- leak down. So we put three dabs of grease down stream of the air filter. "K&N" The next engine came in with 3%-leak down new. And at the end of the race 32%- leak down and the dabs of grease were full of grit. So we changed the filter to a oiled foam filter. 3%- leak down new and at the end of the next race? 18%-leak down. Better still not good. So we made a new air box and used a Mustang GT stock air filter. 3%-leak down new at the end of the next race? 1%- leak down, yes I said "1%". The rings bed in and the engine seals up. We went from changing a engine at 300 miles with 29 to 34% leak down to changing the engine at 800 miles with 7% leak down.
So the bottom line is. You might gain a little more power (1 to 2hp) but it will not last long and before you know it you will have a LOT less.
I work on 944s only and when I tear down a 944 engine that has had a K&N filter the cylinders have a LOT of scoring from dirt that got through the filter.
If you dont beleve me do the grease test your self. Take out the filter and put a dab of grease in the air box. Then put your K&N filter in and drive the car for a few weeks and pull the filter out and check the dab of grease.
Im not going to say its a rigged test, but in all my years of fabrication and testing, ive still not found how you can take two gauze type base filters of compareable size, and the one that filters more dirt (ie turbulates causing drag, and captures small particles of dirt) is the one that also makes the most amount of HP. Haha , that just doesnt make sense unless you increase the surface area.
Tagged wrote:hmm looks like I've got quite some stuff to buy there....![]()
anyways thanks to you all for your replies!!!![]()
oh one thing thats been in my mind for quite a while is; whats the difference between an axle stand and those jacks that comes with the car? I mean they both do the same job as to lifting cars up right?
and I bought this car with "Calibre" pod filter fitted in, any1 know anything about Calibre stuff? like are they good or not.
Snaps wrote:To elaborate on how to jack your car up - to make sure you don't hurt yourself or your car.... Lift it up with a jack, in the right place (not sure where this is on the AE111's (?)), then place two axle stands underneath the car, once again in the right places. Extend the axle stands enough to give yourself enough room. You then need to make sure you re-lower the car onto the axle stands, so it's them holding the car up, not the jack.
Putting the car back down is the opposite, jack the car off of the axle stands, take the stands out, lower the car. Simple.
