sr20det fuel surging?
Postby GT4-Addict » Wed Nov 10, 2010 6:45 pm
Im looking at buying a nissan silvia, s14 facelift sr20det engine with aparrantly 130,000kms put in it (No reciepts so im being pretty cautious!)
it seems to run fine, i took it for a pretty good run, temperature didnt jump up at all, stayed about 1/3rd of the way up on the gauge, pulled really good on both 10psi and 14psi. it has a rattle on some downchanges, i think it is an exhaust rattle, but i am also wondering if it could be gearbox bearings?
Also after going for a good run, while it was idling its started to surge a bit, the fuel pressure regulator wasnt picking up any pressure change in the fuel supply, so im wondering what it could be? Im just worried about this as there is no reciepts garrunteeing the engine is only 130,000kms.
on another note, it sounds a bit clunky in the rear when you take off in first, and when its up on the hoist if you spin one rear wheel the other side spins at exactly the same rate. Im thinking this means the diff has been locked/welded?
Anyway, if anyone out there knows a thing or two about sr20dets, id greatly appreciate some advice about the surging!
GT4-Addict
Postby Quirky » Wed Nov 10, 2010 9:51 pm
As they say on Wheeler Dealers...
...Walk away.
Hello There
Quirky
Re: sr20det fuel surging?
Postby MAC_HATER » Wed Nov 10, 2010 9:58 pm
GT4-Addict wrote: Im just worried about this as there is no reciepts garrunteeing the engine is only 130,000kms.
be very worried - run for the hills - if the owner(s) cant complete the simple task of taking a receipt and sticking it in a shoebox or asking the previous owner for them - the same laziness has probably crept into the car
if you cant find any solid proof that the claimed work has been done via receipts leg it and dont look back - its not the last Silvia in the world and there will be one where the owner has kept a full service history for it so you know what you are getting
might sound a bit damning but ive seen too many friends buy cars in a rush (gimmie gimmie shell be right!) and have them fail and sit around as a doorstop for months till they can afford to fix them
~SlideWays~: Cars + Males = Single, therefore: Poptarts?
MAC_HATER
Postby Dell'Orto » Wed Nov 10, 2010 10:10 pm
Clunky diff could be just a tight aftermarket one, they dont feel too dissimilar to lockers.
Surge at idle could be a manner of things.
Unless the price is right, there are others out there, and if it doesnt have proof of the new motor, then it didnt happen.
Postby d1 mule » Wed Nov 10, 2010 10:54 pm
hunting at idle would either be vac leak or temp sensor problem.
clunk could be roooted factory LSD/ backlash not correctly set in diff
all the bad box bearings iv come across whine not clunk
d1 mule
Postby GT4-Addict » Wed Nov 10, 2010 11:20 pm
I reckon i will leave it for now then, its not really exactly what im after,Its just a really cheap price (and you know what they say about deals that are to good to be true right?), and a great fun car to drive.
I think i will carry on with my original plans of finding a really nice st205 gt-four to replace my current st185 and get something i know i will be happy with
GT4-Addict
Postby matt dunn » Thu Nov 11, 2010 12:07 am
GT4-Addict wrote:I think i will carry on with my original plans of finding a really nice st205 gt-four to replace my current st185 and get something i know i will be happy with
What do you want to spend on a Good ST205?
Postby GT4-Addict » Thu Nov 11, 2010 5:19 pm
As of yet im not sure. i was looking at 8g for the silvia, so ideally the same or less preferably haha
GT4-Addict
Postby matt dunn » Thu Nov 11, 2010 10:41 pm
GT4-Addict wrote:As of yet im not sure. i was looking at 8g for the silvia, so ideally the same or less preferably haha
Well then the one I was going to mention is way out of your range.
Postby h8wrxs » Thu Nov 11, 2010 11:26 pm
regardless wether the car has receipts or not be very wary of buying a silvia in the first place
most people that own silvias treat them like shit anyway
h8wrxs
