tacking noise when passenger in car ae111
Postby gleem » Sun Nov 21, 2010 9:45 am
ae111. Has a pretty loud tacking noise aqs id there was a nail in the tyre and would click on every rotation. This sound appears pretty much every time some one over 70kg ish in the passenger seat?
Also has a horrible gittery sound and feeling when on full lock. this is not rubbing!! i am running 17s with 205 40s
gleem
Postby ATAl » Sun Nov 21, 2010 11:10 am
Maybe something is horribly wrong with your cv joints?
ATAl
Postby gleem » Sun Nov 21, 2010 1:04 pm
what i suspected but what has that got to do with weight on the left hand side?
gleem
Postby ATAl » Sun Nov 21, 2010 1:31 pm
The weight on the left hand side would be putting the cv at a different angle from usual, possibly into the area it's damaged.
But before you pull out your cv, are all the wheel nuts tight? You get a clicking noise if they are a wee bit loose.
Also, have you tried jacking the car up and rotating that wheel by hand, you might be able to see something rubbing.
ATAl
