.:O4AGTZ:. wrote:As above, could be supercharger clutch but there are other things as well.
Do you get an engine check light on at all? More common on ae101, but my ae101 GTZ would jump into limp mode every now and again due to melting caps in the ECU.
Other thing I can think of is the ABV mod, but I dont think that would give those symtoms, it would just limit it to factory boost.
MR2SIK wrote:could be the relay, which is behind the carpet on the back wall of the boot?
evil_si wrote:im pretty sure on an ae92 the relay is by the front left strut tower in engine bay,
definitely not in the boot,
tsoob wrote:Turbo it
-Dan-Knee- wrote:
Does anyone know if the TPS would likely cause the no boost issue due to a possible Safe Mode?
Yes, it will.
