KE35 + Hilux Diff - Clearance issue
Postby lorolla24 » Wed Dec 15, 2010 4:52 pm
Hi,
KE35 with 50mm lowering blocks and early hilux diff.
Just wondering if more people have the problem of the hilux diff head being really close to the chassis? Mine has about 30mm clearance.Without the center bump stop.I can't get the bump back in beacuse it is to big.
When i push the back down with a good about of weight it hit's.
Any solutions?
Ke35 20v turbo - 200kw atw 13psi
13.5@169km
lorolla24
Postby al_feinted » Wed Dec 15, 2010 7:42 pm
Cut out your diff tunnel and refit it a bit higher. Or if you dont want to go to those lengths use smaller lowering blocks.
If you dont like the higher ride height run some 13" wheels with low profile tyres. (If you can fit 13's over your brakes??)
All i can think of.
Project cars: 83 corona tt142, 83 corona mark2 gx61, 82 avante chaser gx61.
www.toycrazy.net
http://toyspeed.blakjak.net/profiles/pr ... hp?id=1408
al_feinted
