A gear knob with no thread
Postby Tagged » Mon Dec 27, 2010 9:16 pm
I got a new gear knob from overseas to fit into my AE111.
The seller told me that the gear knob would fit into any shifter with M10 thread. I checked the internet and thinks my shifter has M10 thread...can some1 clarify this for me though? im not too sure
anyways, I got the gear knob and found that theres no thread in it at all....
What can I do to get the gear knob to fit on to my car??[/img]
Tagged
Postby gasman » Mon Dec 27, 2010 9:32 pm
run a tap down the knob and make a thread.
if you dont have a tap then take it to a mechanic who does, should take more than 15min.
"What can possibly go wrong?"
gasman
Postby Bling » Mon Dec 27, 2010 9:42 pm
It didn't come with any other parts? Generic type gear knobs usually come with fitting kits that use allen keys to fit it to your gear stick. Hard to say though without seeing what you got.
Postby Tagged » Mon Dec 27, 2010 10:01 pm
gasman wrote:run a tap down the knob and make a thread.
would normal garage mechanics have them?
Tagged
Postby Tagged » Mon Dec 27, 2010 10:08 pm
BZG|Bling wrote:It didn't come with any other parts? Generic type gear knobs usually come with fitting kits that use allen keys to fit it to your gear stick. Hard to say though without seeing what you got.
it didnt come with anything....just the gear knob on it self.
And here are the images of the shifter with measurements
http://img69.imageshack.us/gal.php?g=20101217289.jpg
btw...how to you link images directly into the thread? not like how I did by posting the link?
Tagged
Postby gasman » Mon Dec 27, 2010 10:40 pm
a good mechanic should have a tap and die set lying around for when he strips a thread like i do.
costs about 100 bucks for a pretty comprehensive kit, so it might be worth getting one your self.
to link pictures directly use the "Img" tags when you reply.
gasman
Postby Tagged » Mon Dec 27, 2010 11:19 pm
gasman wrote:a good mechanic should have a tap and die set lying around for when he strips a thread like i do.
http://img69.imageshack.us/img69/9851/20101217289.jpg
this is wat i got from how i thought it should work lol....what am I doing wrong?
Tagged
Postby Bling » Mon Dec 27, 2010 11:24 pm
Fixed the link for you, but the image is way too big. Plus we already know what a gear stick looks like, what the gear knob looks like is what we need. But if it didn't come with any other parts and isn't threaded already then that's strange.
When linking to images, make sure they are say 800x600 pixels in size, and make sure you're linking to the image itself. Right clicking the image and copying the image url usually works, then paste that between [img].....[/img] tags
Postby Tagged » Mon Dec 27, 2010 11:50 pm
BZG|Bling wrote:Fixed the link for you, but the image is way too big. Plus we already know what a gear stick looks like, what the gear knob looks like is what we need. But if it didn't come with any other parts and isn't threaded already then that's strange.
oh right~ ok let me try again;
Tagged
Postby Emperor » Mon Dec 27, 2010 11:52 pm
Does it not just screw in to the plastic?
Subarus gearknobs have the same insides, the plastic inside the knob just threads onto the gear shifter with a bit of force...
If not, just like everyone else said, go borrow an M10 tap and it should screw on easy.
If the inside of the knobs to big, then you could possibly glue a 10mm riv nut inside the knob.
Emperor
Postby Tagged » Tue Dec 28, 2010 12:02 am
Emperor wrote:Does it not just screw in to the plastic?
Thats actually what I thought at the start, so I tried....and it didn't work...all it did was scraping off bits and pieces of plastic....so I stopped in fear of screwing up the whole thing.
The inside seems a but smaller rather than bigger than the shifter, but I guess it should be fine if I will using a M10 tap to treaded right?
Tagged
Postby Tagged » Tue Dec 28, 2010 12:13 am
oh and I am not entirely sure if the shifter is on M10 thread......and even it is, theres things like M10x1.25 and M10x1.5.....I really have no idea what they are and which one does my shifter belongs to.....can any1 clarify this for me? thanks!
Tagged
Postby Bling » Tue Dec 28, 2010 12:47 am
You sure it won't screw on? It would need to be a tight fit otherwise it would not grip to the thread
Postby Tagged » Tue Dec 28, 2010 2:36 am
BZG|Bling wrote:You sure it won't screw on? It would need to be a tight fit otherwise it would not grip to the thread
I tried pretty hard screwing it in but didnt work....is it common for gear knobs to come in this form and require brute force to screw its way in? maybe I should ask the seller too @@"
Tagged
Postby Emperor » Tue Dec 28, 2010 9:06 am
Yes, it's quite normal. Like I said Subaru have that setup, and removing and re-fitting the knob was quite difficult with my old Forester.
Being plastic it won't really matter if its M10x1 or 1.25, as it'll just make its own thread as it goes anyway.
Try a bit of grease and some force.
Emperor
Postby Tagged » Tue Dec 28, 2010 3:15 pm
an update to this topic....
I checked with the seller and he told me there is M10 thread inside its just really not obvious. I think he is right as I can kind of see the thread under direct lighting.
So now there is thread but it doesn't screw on.....which probably means that my shifter isn't M10 thread.....any got any idea who do I identify what thread is my shifter? thanks
Tagged
Postby Bling » Tue Dec 28, 2010 3:27 pm
If its the same as pre facelift ae111s then at a guess its M12 1.5 or 1.25. Can't confirm though as I can only find my M12 1.75 tap :oops: And i'm pretty sure its not that.
So you could always try drilling the centre out a bit more
Postby Tagged » Tue Dec 28, 2010 3:59 pm
BZG|Bling wrote:If its the same as pre facelift ae111s then at a guess its M12 1.5 or 1.25. Can't confirm though as I can only find my M12 1.75 tap :oops: And i'm pretty sure its not that.
hmm....i guess it would be easier if I go buy another one and sell this one....LOL
Tagged
Postby h8wrxs » Tue Dec 28, 2010 4:44 pm
use a bit of kiwi diy skills and make it fit any way you can
its only a gearknob, dont bother going and buying a new one just drill it out and make it fit
h8wrxs
Postby Tagged » Tue Dec 28, 2010 4:49 pm
h8wrxs wrote:use a bit of kiwi diy skills and make it fit any way you can
I was wondering if drilling M12 thread onto an existing M10 thread would screw the whole thing up.....
Tagged
Users browsing this forum: Google [Bot] and 17 guests
