RWD 3a to 4age swap
RWD 3a to 4age swap
Postby dxtawagon » Sat Jan 08, 2011 5:37 pm
Hi There,
quick question....
can i use the water pump, alternator (and bracket) and pulley off a rwd 3a engine on a rwd 4age engine?
i think it should bolt up as 3a block is the same as 4a??? not sure if the alternator would be up to the job though? 3a also has smaller alt belt.
dxtawagon
Postby d1 mule » Sat Jan 08, 2011 7:50 pm
just use everything off the engine you buy, all fwd is sweet just gota piss about with the water lines a bit more
d1 mule
Postby QikStarlie » Sat Jan 08, 2011 8:03 pm
about the only thing of use is the back half of the water pump. even then may as well buy a new pump. as above just use the fwd stuff. or buy all the rwd stuff. mix and match of rwd and fwd doesnt work.
QikStarlie
Postby dxtawagon » Sun Jan 09, 2011 7:29 am
sweet cheers. thanks for the input!
dxtawagon
Users browsing this forum: Bing [Bot] and 21 guests
