BT 20V Rough Idle and Loose Vacuum Hose
Postby DUGDUG » Sun Jan 09, 2011 9:51 pm
Hey guys.
My BT 20V is idling real low ~400rpm and rough and I'm pretty sure it's due to a loose vacuum hose. For some reason it's just sitting there not connected to anything. Can you guys tell me where it's suppose to go?
This isn't my car but it shows which vacuum line I'm talking about. It's the line coming off the white canister type thing that's located next to the TPS in the photo. On my engine a line comes off from under the fuel rail to the white canister then the line isn't connected to anything. So in relation to the picture my line doesn't loop back under the fuel rail. Where's it supposed to go?
Thanks in advance.
DUGDUG
Postby gasman » Sun Jan 09, 2011 10:50 pm
map sensor is where it usually goes to i think, and the white thing is a dampener/choke to even out the pulses from the runners.
is there a hose connected to your map sensor?
"What can possibly go wrong?"
gasman
Postby whynot » Sun Jan 09, 2011 10:53 pm
I Think that line is for the MAP sensor which would also explain the poor idle. the sensor should be on the drivers side strut tower but could be wrong on that as I haven't worked on one of those in the correct engine bay for a while.
whynot
Postby 1I1 » Mon Jan 10, 2011 9:38 am
whynot wrote:I Think that line is for the MAP sensor which would also explain the poor idle. the sensor should be on the drivers side strut tower but could be wrong on that as I haven't worked on one of those in the correct engine bay for a while.
Yeah MAP sensor hangs off the strut brace by strut tower
TRD Clicky >>Here
1I1
Postby DUGDUG » Mon Jan 10, 2011 10:09 am
Spot on guys, thanks for your help.
Now to deal with my squeaky AC pulley's :)
DUGDUG
Users browsing this forum: Bing [Bot] and 21 guests
