Hot or cold plug?
Hot or cold plug?
Postby cat007 » Thu Jan 13, 2011 12:09 pm
Hey all.
What do people think about running a hot or a cold spark plug in my 1G? Running 98octane gas
Hunt
Postby QikStarlie » Thu Jan 13, 2011 12:16 pm
maybe go a number colder than factory going by whats in you sig. 7's
QikStarlie
Postby mjrstar » Thu Jan 13, 2011 3:15 pm
i run 7's in mine and it doesn't have any miss-fire issues since switching to mitsi coils.
current cars:
Evo 4 230Kw atw
1971 mini.
79 bugeye 245kw atw.
mjrstar
Re: Hot or cold plug?
Postby allencr » Thu Jan 13, 2011 3:35 pm
cat007 wrote:What do people think about running a hot or a cold spark plug in my 1G?
Nothing.
It's completely dependent on what range it's running now & what it looks like, or if the engine is going to be run any differently then it is right now.
Track day? Otherwise the question doesn't make any sense and the octane is almost irrelevant.
http://www.dansmc.com/Spark_Plugs/Spark ... talog.html
http://www.dragstuff.com/techarticles/r ... plugs.html
http://www.strappe.com/plugs.html
allencr
Postby Quirky » Thu Jan 13, 2011 3:36 pm
I have 4ag turbo and i just use normal plugs, normal gaps.
How would you know when to use colder plugs?
The car runs perfectly smooth otherwise.
Do you try colder plugs when it starts to mis-fire?
Or is it a good idea to use colder plugs anyway?
Hello There
Quirky
Postby MAGN1T » Thu Jan 13, 2011 5:49 pm
If it's not broken, it doesn't need fixing.
Colder plugs might tend to misfire at lower loads/RPMs but might be a bit better when flat out.
Hotter plugs might be better for a worn out motor that fouls stock ones.
Steve
Computers make you go mad.
MAGN1T
!USER HAS BEEN BANNED!
Users browsing this forum: Bing [Bot], Google [Bot] and 7 guests
