FLESHAXXE wrote:Does anyone have the wiring diagrams for both silvertop and blacktop ...the ST has four wires comming from it and the BT has three..
RomanV wrote:I've got a blacktop 4AGE throttle set and TPS, and it's 4 pin?
The 4th pin is just a switch that tells the ECU when the throttle is completely shut, presumably for idle speed control or something.
iOnic wrote:3 wire TPS is just a switch - Only tells the ECU if the throttle is open or closed - not how much. The MAP sensor tells it everything else it needs to know about how you are accelerating.
4 wire TPS is a true potentiometer and tells the ECU exactly how much throttle you're giving it so it can make changes.
people wrote: stuff
sergei wrote:The plug on blacktop is missing one of the wires (for the IDL switch). I am not sure but there is possibility that the actual TPS has it in place.
