Ignitor for 6cyl wasted spark setup?
Postby cat007 » Tue Jan 18, 2011 8:50 am
Hey all
Just wondering if anyone has any suggestions for a decent ignitor for my 1G running 3 7M wasted spark coils?
Currently using some sort of Mitsi V6 jobbie and wondering if upgrading it will give me a better spark?
Hunt
Postby mjrstar » Tue Jan 18, 2011 9:02 am
I run a link 3 channel ignitor which has not given me any trouble.. Unsure if it would really give you any gain over a factory setup though..
current cars:
Evo 4 230Kw atw
1971 mini.
79 bugeye 245kw atw.
mjrstar
Postby cat007 » Tue Jan 18, 2011 9:09 am
Wonder if something like this would be ok - but the triple channel one:
http://www.trademe.co.nz/Trade-Me-Motor ... 869278.htm
Postby cat007 » Tue Jan 18, 2011 9:13 am
Actually - flag that - Maybe I should just get one of these as they're designed to run with my ECU:
http://www.enginemanagement.com.au/prod ... cts_id=132
Postby strx7 » Tue Jan 18, 2011 9:31 am
V6 mitsi ones are all good. if you want better spark, you'd be better off changing the coil packs.
series 4/5 rx7 coil packs pack a helluva whallop if you need more oomph
Postby cat007 » Tue Jan 18, 2011 9:34 am
Postby tsoob » Tue Jan 18, 2011 9:45 am
cat007 wrote:yeah? Something like this perhaps?
http://www.trademe.co.nz/Trade-Me-Motor ... 194471.htm
yeah you should just by it and restore it bro... won't take long :D
Platinum Wheels
15 Parkway Drive
Mairangi Bay
09 486 5317
WHEELS, TYRES & SUSPENSION!
www.platinumwheels.co.nz
tsoob
Postby Py7h0n » Tue Jan 18, 2011 4:09 pm
Py7h0n
Postby cat007 » Tue Jan 18, 2011 4:17 pm
Haha that's a bit out of my price range. Especially as I'd need coils to go with it!
Postby Py7h0n » Tue Jan 18, 2011 4:18 pm
I run non cdi coils and I have no problems with Ethanol at 34psi boost :P
Py7h0n
Postby cat007 » Tue Jan 18, 2011 4:27 pm
Py7h0n wrote:I run non cdi coils and I have no problems with Ethanol at 34psi boost :P
How much were the coils worth?
Postby strx7 » Tue Jan 18, 2011 4:29 pm
what kinda coils are you running?
Postby Py7h0n » Tue Jan 18, 2011 4:29 pm
My bosch coils ... Like $40 each?
Py7h0n
Postby cat007 » Tue Jan 18, 2011 4:30 pm
Py7h0n wrote:My bosch coils ... Like $40 each?
Sweet - I'll see how much the dual post ones are....
Was that from Petro-ject? I bet that's not retail though aye... :wink:
Postby Py7h0n » Tue Jan 18, 2011 4:32 pm
I'm running run of the mill bosch coils - Like these:
http://www.tfelectronics.com.au/images/ ... lbosch.jpg
Py7h0n
Postby QikStarlie » Tue Jan 18, 2011 4:58 pm
ignitor is pretty much a relay. (some have built in dwell control though) just grounds the coils. so your not going to gain anything changing them, unless current is junk. how much dwell are you running?
QikStarlie
Postby MAGN1T » Tue Jan 18, 2011 5:38 pm
Can't go wrong using Mitsi coils with mitsi igniter. Mitsi igniters have the dwell control built into them.
Plenty at pick a part.
Steve
Computers make you go mad.
MAGN1T
!USER HAS BEEN BANNED!
Postby cat007 » Tue Jan 18, 2011 5:39 pm
MAGN1T wrote:Can't go wrong using Mitsi coils with mitsi igniter. Mitsi igniters have the dwell control built into them.
Steve
Really? Not from what I've been told - that's why I went with this one. The 7M ignitor, which I was originally going to use, has dwell control built in, hence why I went for the Mitsi ignitor
Postby strx7 » Tue Jan 18, 2011 6:12 pm
the mitsi ignitior i'm using doesn't have dwell control built in, its set in the ecu software.
Postby cat007 » Tue Jan 18, 2011 6:16 pm
Mine looks like this:
Users browsing this forum: Google [Bot] and 21 guests
