Hey,
Wondering if anyone has knowledge/guidance/warnings when trying to lengthen suspension arms.
I'm specifically looking to add 8-12mm to the length of my AE82 front lower suspension arms.
I just need the knuckle to move out this much so I can either find a longer ball joint that bolts on the arm (no luck so far) or weld metal (plate/sheetmetal) to the arm and redrill the ball joint mounting holes 8-12mm further out?
Anyone done this? It needs to be a strong fix as it's a GZE tarmac Rally car. I have been recommended Machine Part Welders in Penrose to do the job if welding is ok (+ heat treatment if required)
The other option is shortening driveshafts but is this expensive/weak in any way?
Thanks, Allister.
