ae111 ignition problem
Postby sik_gt_starly » Thu Jan 20, 2011 2:13 pm
my flatmate is having troubles with her blacktop 20v levin
will not start, motor turns over and over and over and nothing
Sparkplugs are not getting any spark
all fuses are in good order
the ignitor is getting power - tested with voltmeter
as is the wire from ignitor to dizzy (not sure what this is called)
no power coming through from spark plug lead side of the dizzy
put ecu into diagnostic mode and coming up with code 12
"RPM SIGNAL-NO SIGNAL TO ECU FROM DISTRIBUTOR ("Ne" OR "G") AFTER ENGINE HAS BEEN CRANKED
--DISTRIBUTOR/CIRCUIT
--STARTERSIGNAL CIRCUIT
--IGNITER/IGNITER CIRCUIT
--ECU "
Ive reached about the end of my knowledge base and not sure where to look next or what to look for
any help very much appreciated
sik_gt_starly
Postby Bazda » Thu Jan 20, 2011 4:11 pm
replace the distributor...
replace the ignitor.
thats where i would start.
Postby Vertigo » Thu Jan 20, 2011 8:55 pm
CASE CLOASED
TVIS just kicked in, yo!
Vertigo
