4AGE engine mount inserts
Postby Vertigo » Sat Jan 22, 2011 10:44 am
so ive got a set of front/back poly engine mount inserts for my adub, and i have a spare set of mounts to practice on before i attempt the real deal. im supposed to be cutting through the rubber and thin steel shell to get the existing mount insert out, apparently it should just slide/pop out when cut through to the outer mount shell, but doesnt want to budge. any tips, or should i just keep forcing it? dont have access to a press, and the instructions say this way is easier!!
TVIS just kicked in, yo!
Vertigo
Postby CAMB01 » Sat Jan 22, 2011 11:02 am
Try making a few more cuts through it. If not you will require a press.
1993 Mitsubishi EVO 1 Racecar
1989 AE91 FX-ZS (Previous)
Custom Works Automotive
http://www.HCCC.org.nz
CAMB01
