2TZ-FE ecu info....
2TZ-FE ecu info....
Postby 3T-Rona » Tue Jan 25, 2011 12:53 pm
Anyone got a pin out for this engine>?
PM me for anything autoelectrical, Info or jobs etc....
3T-Rona
Postby AE25 » Mon Jan 31, 2011 7:32 pm
go pickapart, pull ecu, take cover off, take pics of printed pinout on circuit board? (assuming its printed)
E2 & E7 fanatic
http://www.toycrazy.net
AE25
Postby 3T-Rona » Mon Jan 31, 2011 10:15 pm
AE25 wrote:go pickapart, pull ecu, take cover off, take pics of printed pinout on circuit board? (assuming its printed)
hahaha wiseguy, they stopped doing that along time ago. :)
I have the ECU with a fried output resistor would like to knw what it does so we can work out how it happened, without having to get the vehicle in etc
3T-Rona
Postby AE25 » Tue Feb 01, 2011 2:24 am
oh doh was worth a shot :?
ask toyota....
E2 & E7 fanatic
AE25
Postby 3T-Rona » Tue Feb 01, 2011 9:01 am
AE25 wrote:oh doh was worth a shot :?
ask toyota....
^^^^^^^ bahahaha ur kidding right :)
3T-Rona
Postby sergei » Tue Feb 01, 2011 9:47 am
No he is not kidding. The ECU pin out will be in repair manual, since the car has been sold as NZ (I assume as previa) there will be a repair manual with TNZ in English. There are also aftermarket repair manuals (like haynes) in your local library (and on torrents/rapidshare) that you can borrow/scan/download.
Oh BTW: if the resistor is blackened/burned it is most likely the output transistor that is upstream of that resistor is fried (just trace the tracks from resistor).
If these ECU are available from pickapart is is more practical to get ECU from there, that is if you don't have skills/equipment to repair your ECU.
Postby 3T-Rona » Tue Feb 01, 2011 7:01 pm
sergei wrote:No he is not kidding. The ECU pin out will be in repair manual, since the car has been sold as NZ (I assume as previa) there will be a repair manual with TNZ in English. There are also aftermarket repair manuals (like haynes) in your local library (and on torrents/rapidshare) that you can borrow/scan/download.
just trying to do the most for the customer with the smallest amount of effort because no one wants to pay for anything sadly,
If you have tried ringing any of the franchise's in Tauranga you would know they generally dont give out that information.
3T-Rona
Postby sergei » Tue Feb 01, 2011 10:59 pm
Send the poor/greedy customer to library :lol:
But seriously, what are the symptoms - what is not working?
Postby 3T-Rona » Tue Feb 01, 2011 11:23 pm
sorry i will try find out when i get back to work next week,
boss just said hey do you have a diagram for this and i said i might be able to interweb one up...........
3T-Rona
Postby AE25 » Fri Feb 04, 2011 1:35 am
toyota parts departments are more likely to help if you're there in their face rather than some guy on the phone :wink: not too hard for them to hand you a manual, you find the page and they photocopy it
E2 & E7 fanatic
AE25
Postby 3T-Rona » Mon Feb 07, 2011 8:09 am
Idle speed contrl 1 coil winding drawing excess current......
3T-Rona
Postby sergei » Mon Feb 07, 2011 9:06 am
3T-Rona wrote:Idle speed contrl 1 coil winding drawing excess current......
Can you trace it to the pin on the ECU?
Then inside trace the pin to the driving transistor. It will be 99% that transistor is stuffed. Actually if you spotted blackened current limiting resistor it is very easy to trace the track back from it to the transistor that has burned out.
Next step is getting numbers off it and finding equivalent. It is 30sec to replace it if you are good with soldering iron. Resistor will need to be replaced as well...
One more thing, before you try new ECU/or fixed ECU make sure that the idle speed control coil #1 is not shorted (measure resistance, it should be a few of Ohms), otherwise if it is shorted it will most likely stuff any ECU you try. Actually come to think, there is a chance that transistor hasn't been blown and ECU still will be fine (apart slightly blackened resistor), a very small chance, if the coil is shorted and drawing enough current to heat up the resistor but not burn out the transistor.
Postby sergei » Mon Feb 07, 2011 9:19 am
Postby 3T-Rona » Mon Feb 07, 2011 8:49 pm
cheers serg,
ISC replaced, ecu repaired.
done
3T-Rona
