Does this seem normal?
Postby FYADUP » Fri Jan 28, 2011 3:48 pm
Hey guys,
I have a 1991 Corolla GT-i hatch with standard redtop smallport (black and red writing) has an exhaust and better panel filter.
I live in Auckland and drive from Parnell in the city to the Airport and back every day for work.
This is approximately 25km each way so over a week you're looking at roughly 125km total driving (excluding weekends)
I seem to be spending around $100 or a bit more on gas a week to go to and from work - I know petrol isn't overly cheap at the mo as I run it on either 95 or 98 only (states inside fuel lid to)
Obviously these are the optimal gas' for the car to make it run its best.
Does it seem like I am spending too much for what it is?
I seem to think it goes a little quickly, but maybe It's normal for the amount of k's I do.
What are your thoughts?
Jason
R.I.P - 90 4AGTE GT-i Corolla Hatch [ROLYOU]
New 91' Corolla GT-i project! WATCH THIS SPACE
FYADUP
Postby sik_gt_starly » Fri Jan 28, 2011 3:52 pm
for arguments sake we will say gas is $2 a litre, your saying your getting 125 kms of driving from $100 gas
50 litres to drive 125kms
2.5kms a litre?? sounds rediculous and something must be very wrong, most 4ages get 10-15km/litre or better depending how they are driven
sik_gt_starly
Postby FYADUP » Fri Jan 28, 2011 3:57 pm
Yer, thought so.
I will do a test in the next week or 2, driving to and from work and starting the first morning on empty. Get some accurate km's to money spent.
It's a rough esitimate, could be a bit more km, but I'll do it properly - still from what you are saying, seem still ridiculous.
I give it a few fangs on the on ramps etc but apart from that not really?
FYADUP
Postby MAC_HATER » Fri Jan 28, 2011 4:08 pm
an easy test is unplug your oxygen sensor - if the problem mostly goes away then you've found the culprit
from what ive seen if an oxy sensor packs up it just tells the computer "FFFUUU IM RUNNING LEAN" and the computer chucks in way too much fuel and you get the likes of what you are getting
MAC_HATER
Postby FYADUP » Fri Jan 28, 2011 4:08 pm
i might also add - Its done almost 300,000km and the idle is a bit off (isn't smooth)
I guess this could be the cause of the high fuel use? Somethings a bit stuffed e.g. AFM, and causing it to over fuel?
FYADUP
Postby Adamal » Fri Jan 28, 2011 4:08 pm
First, you might want to go over your math again if its 25km each way
Postby sik_gt_starly » Fri Jan 28, 2011 4:12 pm
:oops: double facepalm, thatl teach me for skim reading and not picking up calc errors
still 5 km a litre is pretty shocking for a 4age
sik_gt_starly
Postby sergei » Fri Jan 28, 2011 4:14 pm
Oxygen sensor will not cause that greater discrepancy, at most it will do 20% worse.
Perhaps leak in fuel system (including leaky injectors) or mis-calculation are the culprits.
Do a fill up to the full, reset trip meter, drive whatever you drive, then fill up again (to the full). Take note of Litres vs Km and post them here.
$120-$140 is full tank, and should give you 400-600kms depending on the driving.
Postby touge_ae101 » Fri Jan 28, 2011 4:24 pm
sergei wrote:Do a fill up to the full, reset trip meter, drive whatever you drive, then fill up again (to the full). Take note of Litres vs Km and post them here.
this. sounds like something is not right have you got a hole in your tank?
either that or some kid down your street is siphoning your gas in the middle of the night. :?
touge_ae101
Postby deaf_rattle » Fri Jan 28, 2011 4:25 pm
just fill tank up, do 100km then fill up again. done
Postby FYADUP » Fri Jan 28, 2011 4:33 pm
HAHA! - Its all my fault starly.
Sorry guys, muppetry end of Friday has kicked in.
I am at work and dreaming about a nice cold beer - mind is not with it!
Just did a manual path plot on google earth - the exact way I drive to work and got 26.5km one way, so was close.
So, during the 5 day working week I drive 265km in total.
Was going to do exactly that Sergei - will give it a go and post up info!
Sorry for being a f%&*tard!
Jason
FYADUP
Postby GDII » Fri Jan 28, 2011 5:35 pm
I drive 44km to work and back and do some weekend driving. 2.0litre SW20 MR2. Costs me an average of $65 of 95 a week. Thats about 260km per week. Something must be wrong if your car uses that much.
1990 SW20 MR2
Previous 1990 EE90 Corolla
GDII
Postby pc » Fri Jan 28, 2011 6:35 pm
$ per week is a meaningless ratio. km per litre is the only ratio that gives an idea of what is going on.
Apparently some factory speedo's are out by lots (so i've heard, haven't seen one yet) so the trip meters could be out by a bit. Check the speedo with a GPS to be sure.
red car
1/4 mile - 14.683s @ 91.83mph
Manfield - 1:24s
pc
Postby metal_sean_head » Fri Jan 28, 2011 7:48 pm
Something is up. My 4AGE bigport does about 350-400kms per tank around town. And like 550km highway driving.
If your revving the nuts off it everywhere this will obviously raise your consumption. If your driving relatively sedately you should expect a lot more kms.
VTEC: All of the lag and none of the boost.
89 AE92 FXGT
Big Port Redtop
TVIS!
19.8@32kph
metal_sean_head
Postby strx7 » Fri Jan 28, 2011 9:07 pm
i have an ae101 with 4afe for a work car. the car itself has done 454,000km, the motor in it has done around 260,000km. I travel 26km each way to work and back each day (pretty much open road all the way), and i gnerally get 400-420km per 40 litres of gas. this car is an auto, i assume yours is a manual. if your daily commute involves lots of stop start in town then that will drop your k's per tank down alot
an ae92 tank is only 50 litres, and your fuel light comes on when youve got around 12 litres left. do you put $100 litres in 1 go? (i cant see how that is possible)
Postby Bling » Fri Jan 28, 2011 9:18 pm
sik_gt_starly wrote:still 5 km a litre is pretty shocking for a 4age
Hell yes it is! I get twice that around town no matter how I drive 8O
Postby darkwolf » Sat Jan 29, 2011 12:12 am
I have a 4.4L V8 and I can get that if I never get into 3rd gear...
Brute force and ignorance always prevails.
Failure comes from too little brute force, or too little ignorance.
darkwolf
Postby levinguy » Sat Jan 29, 2011 1:20 am
strx7 wrote:an ae92 tank is only 50 litres, and your fuel light comes on when youve got around 12 litres left. do you put $100 litres in 1 go? (i cant see how that is possible)
yeah, pretty much impossibile to get 100 in from when the fuel light comes on.
levinguy
Postby allencr » Sat Jan 29, 2011 5:28 am
FYADUP wrote:HAHA! - Its all my fault starly.
Good, now all anyone needs, maybe even you, is the quantity and not the $$ or octane or the colour of the car.
allencr
Postby blindnz » Sat Jan 29, 2011 8:57 am
allencr wrote:Good, now all anyone needs, maybe even you, is the quantity and not the $$ or octane or the colour of the car.
Sure knowing the exact km/l is better but knowing that $100 of 95 or 98 at ~$2 a litre and hes doing around 250 kms per week.
That seems like shitty fuel consumption to me. At the moment im looking at my silver top because it only gets around 10l/100km overland. which is more then I think it should be using let alone approx 20l/100
blindnz
Users browsing this forum: Google [Bot] and 24 guests
