3t backfire on deceleration
Postby Hachiroku » Sun Jan 30, 2011 3:21 pm
My carby 3t powered TT141 seems to be backfiring on deceleration. Compression is good across all 4 and timing has just been set, plugs and points etc are all new. Any ideas on likely cause?
Hachiroku
Postby GDII » Sun Jan 30, 2011 4:25 pm
No idea but my parents 3T TT141? wagon did it going down hills.
1990 SW20 MR2
Previous 1990 EE90 Corolla
GDII
Postby Prymal » Sun Jan 30, 2011 5:28 pm
my 2tb had a nice burble off throttle going down hills and such as well , not backfiring , but popping a little at random intervals.
Al 2t's ive had did the same
St205 NZ New Group A WRC Gt4- Accept no Imitations !
Prymal
Postby Brawler » Sun Jan 30, 2011 6:56 pm
Back firing, like when going down hills??
My carby hilux did that when i had a HOLE in my exhaust, mean backfires etc.
And my 1ggte supra done that too, it was fuel injected and i think, Done it because it wasnt wired up to shut the injectors off going down hills etc if you catch me
zing! Sig got nuked. Sorry bout that.
Brawler
Re: 3t backfire on deceleration
Postby fangsport » Sun Jan 30, 2011 7:30 pm
Hachiroku wrote:My carby 3t powered TT141 seems to be backfiring on deceleration. Compression is good across all 4 and timing has just been set, plugs and points etc are all new. Any ideas on likely cause?
take it for a decent thrash with decent fuel. could be sooted up in the chambers.
fangsport
Postby MAC_HATER » Sun Jan 30, 2011 9:49 pm
my TT141's 3T did it when it was carbied and it still does it now after converting it to EFI and a Tune ect
it doesn't seem to be hurting anything and i can live with it so it doesn't bother me
MAC_HATER
Postby AE25 » Mon Jan 31, 2011 7:27 pm
hole in exhaust?
weak ignition?
lean mixture causing misfire?
intake manifold leak?
PCV valve failure?
my 5k does it, but it running lean on the primary jet (4k carb) and hole in exhaust doesn't help.
E2 & E7 fanatic
http://www.toycrazy.net
AE25
Postby AE25 » Fri Mar 25, 2011 9:25 am
removing or replacing the PCV valve fixed my rough idle in the end. after figuring out that it ran better by richening up the idle mixture screw that i had an intake leak somewhere. but after dousing the whole intake with water and checking for idle speed variations the only thing left was hoses coming off the intake. didn't have a brake booster. the pcv valve when removed dropped my idle heaps when put my thumb over it. this is normal, but i think mine is more than normal. getting new one soon
E2 & E7 fanatic
AE25
Postby CelicaGT8 » Fri Mar 25, 2011 2:50 pm
Sounds cool, leave it
CelicaGT8
Postby cozmoid » Sat Mar 26, 2011 8:47 pm
Yeah it does sound cool and it is incredibly common for carby vehicles. I wouldn't be worried.
Ae70/Te71 Hybrid
viewtopic.php?t=54364
cozmoid
Postby 85AW20v » Sat Mar 26, 2011 11:44 pm
Carby motors keep sucking fuel through the carb on deceleration so its usually unburnt fuel igniting in the hot exhaust system. If you want a really good backfire, turn off the key going downhill with your foot hard on the throttle then turn the key back on....... :twisted:
See ya
Simon
85 MR2 20v
85AW20v
Postby MAC_HATER » Sun Mar 27, 2011 12:58 am
85AW20v wrote:Carby motors keep sucking fuel through the carb on deceleration so its usually unburnt fuel igniting in the hot exhaust system. If you want a really good backfire, turn off the key going downhill with your foot hard on the throttle then turn the key back on....... :twisted:
side effects may include old people and dogs exploding and possible calls to the cops if you do it too many times in the same place at the same time in a very small rural town >_>
those were good times if i remember right :D
MAC_HATER
Postby Boosted_162 » Sun Mar 27, 2011 8:56 am
We used to do that in the old U12 bluebird with a carby CA20 :lol: :lol:
Postby cozmoid » Sun Mar 27, 2011 11:28 am
Haha I did that once in my old corona wagon while passing some road workers. One of them shat himself and the shovel he had been holding went flying! Super classic.
Ae70/Te71 Hybrid
cozmoid
Users browsing this forum: Bing [Bot], Google [Bot] and 10 guests
