No bost boss - non toyota
Postby eskimo » Wed Feb 02, 2011 11:20 am
This isnt toyota related but thought id pick ya brains for idea's
A mate of mine bought an evo 7, she has had it the last week and she finally let me take it for a drive
When I did I realised it wasnt boosting over 3PSI, from what I can find on the net they should at least run 7-8PSI in facotry trim
It is factory apart from a K&N intake(POD ect) & warlboro 255lhr fuel pump(as mitsi wanted moon beans for the genuine one) it has only done 103,000kms
Ive cheacked for boost leaks and cant find a single one any where.Does any one know what could be causing this or what else I should check?
Jordon
"If in doubt, flat out" Colin McRae 1968-2007
Current:2003 Legacy 3.0R Spec B
Previous: ST185 GT4, SW20 MR2, ST206 Curren, AE111 Corolla GT
eskimo
Postby KwS » Wed Feb 02, 2011 12:32 pm
Couple of things come to mind,
Blocked exhaust/cat
boost leak
shagged turbo
wastegate not closing properly
KwS
Postby ~SlideWays~ » Wed Feb 02, 2011 12:51 pm
Do they have a 'limp' mode?
~SlideWays~
Postby eskimo » Wed Feb 02, 2011 12:57 pm
Cheers, will check the exhaust and for leaks again. The turbo is seems ok, spins freely and no play in it
have also looked at the wastgate actuator and that doesnt seem to be sticking either.
Dont think its in limp mode.
eskimo
Re: No bost boss - non toyota
Postby Leon » Wed Feb 02, 2011 1:17 pm
eskimo wrote:she
Maybe it has had a "Woman Driver Detected" error, and wound the boost back?
:lol:
Just kidding :wink: But it was just such an obvious potential troll moment that I had to make the joke. Please form a queue to the right for throwing rocks at Leon.
Postby edwagon » Wed Feb 02, 2011 1:43 pm
KwS wrote:Couple of things come to mind,
Blocked exhaust/cat
boost leak
shagged turbo
edwagon
Postby sik_gt_starly » Wed Feb 02, 2011 2:03 pm
un plug vacume line from wastegate, take to 100km area or similar, drive it nicely in 5th and give some gas, watch boost level and see if it goes higher than 3 psi (be careful doesnt go reduculously high)
i thought evos ran 16psi or so standard
sik_gt_starly
Postby eskimo » Wed Feb 02, 2011 3:10 pm
Sweet, will give that a go
eskimo
Postby h8wrxs » Wed Feb 02, 2011 3:55 pm
nah evos dont run 16psi stock, the wrxs run about that i think though
evos are more like 8-10 i think
freeboosting is fun lol my old one went off the boost gauge at 30psi lol
h8wrxs
Postby sergei » Wed Feb 02, 2011 4:28 pm
h8wrxs wrote:nah evos dont run 16psi stock, the wrxs run about that i think though
If they would run 8-10psi they would not go very fast. 2.0 + 8-10psi is ~ 220Hp at the motor.
They run similar boost to WRX STI of the same era.
Postby B1NZ » Wed Feb 02, 2011 5:17 pm
This is what I thought too, I know my old STi boosted at 16psi and spiked to about 18psi - I would have assumed Evos were the same
Subaru GF8 Wagon
Subaru GC8 rally car project
B1NZ
Postby KwS » Wed Feb 02, 2011 5:32 pm
i would've guessed 1 bar for a late model EVO, personally, but interwebs seem to indicate stock boost at just over a bar (1.1-1.2).
KwS
Postby Akane » Wed Feb 02, 2011 5:52 pm
IIRC stock EVO 7 run 1.2bar+ stock.
Postby tsoob » Wed Feb 02, 2011 5:57 pm
17 psi approx is factory...
does it have a major leak or crack in the cooler pipes? must be slow as $&#$%.
is the gauge giving a faulty reading?
Platinum Wheels
15 Parkway Drive
Mairangi Bay
09 486 5317
WHEELS, TYRES & SUSPENSION!
www.platinumwheels.co.nz
tsoob
Postby rollaholic » Wed Feb 02, 2011 6:03 pm
yeah how does it drive? dodgy gauge would have been my first pick
Postby eskimo » Wed Feb 02, 2011 7:12 pm
Drives like a 2ltr NA car..just has no boost... revs fine and gauge is showing 3psi
She will be bringing back later tonight so will go over it again for leaks
eskimo
Postby dnalunchie » Wed Feb 02, 2011 7:37 pm
Yeah agreed, evo 7's run at least 15psi , closer to 20
Current: 90 3sfe Corona
dnalunchie
Postby KwS » Wed Feb 02, 2011 7:43 pm
Is the back end covered in black soot? would indicate if it was running pig rich from an intake leak or something.
Does it take ages to get to 3psi, or does it quickly jump to 3psi then hold there?
KwS
Postby eskimo » Wed Feb 02, 2011 7:45 pm
Nope, the back end is clean. It takes a wee while to get there but just stays there from then on
eskimo
Postby tsoob » Wed Feb 02, 2011 8:07 pm
turbo wheels $&#$%?
Platinum Wheels
15 Parkway Drive
Mairangi Bay
09 486 5317
tsoob
